Hello!
I would like to build an tubeamp with KT88 tubes. I need some good advise for a tubeamp-kit that comes with an enclosure that look nice, eg aluminium or some else other neat.
Regards Martin
Regards Martin
Hello!
Regards Martin
And your budget is?
I thint the ST120 looks a bit too rough, you can see the pcb and the coloured caps. has you got some other suggestions?
I would like to end up with something looking like the Music Angel KT88, but want to build it myself 🙂
I think the ST120 looks a bit too rough, you can see the pcb and the coloured caps.
I agree.
No. Full kits are hard to find.
jeff
a SET tube amp kit using KT88, well within your budget can be found right here on diyaudio.
http://www.diyaudio.com/forums/vendors-bazaar/180897-kt88-se-basic-master-kit.html
Here's a PP kit
Push-pull KT88 class A amp with "universal" driver PCB
Here's a PP kit
With some creative wiring and a cover for the transformers in the back, you will have a nice and easy to maintain amp. There are builds with the capacitors rewired so you can move them to the underside leaving the gain tubes for show.
I am looking at the Bob Latino ST-70 running with KT-88 tubes as a project. The transformers will handle it and I can go from triode to pentode mode at a flip of the switch. Biasing will also breast too.
Read up on the mods and reviews -- you might be surprised.
This is a good KT88 monoblock that should easily fit your budget.
Yes, the Odd Block looks nice 🙂 Something like that is what I want. I prefer a stereo-version but mono blocks colud be an option.
Here's a PP kit
This is interesting. The mater kit with transformers and housing is the best option I think. Is it possible to ship these kits to Norway? What about pricing?
If you are referring to the SE kit, note that the power transformer has primary 120V/240V - 50/60 Hz.
Send a PM to scitizen77 for shipping or other questions.
- Tubes / Valves
- Suggestions for an tube-amp with KT88
