Hello,
I am hoping to find out about the Pass Labs B4 crossover I have heard about.
Is this available for sale yet? Price?
I am hoping to find out some technical details of this unit if anyone can share about it.
I read about prototypes being in the field a few months back but haven't heard much since.
I was hoping to find out if it offers level adjustment for using different sensitivity drivers/amps.
I also am hoping to find out the crossover points.
Thanks for any help you can provide.
-Nick
-Nick
The B4 is a First Watt piece. There were 10 prototypes made
and floated around.
The initial design was strictly geared around full range drivers
used with woofers, both in open baffles, which included some
appropriate EQ circuits.
There is another design which is simply a crossover without the
EQ features.
Currently I'm working up the final artwork for a product to
appear in a couple months or so.
and floated around.
EQ features.
Thank you very much for your response Mr. Pass.
I appreciate your help.
I will keep my eyes open for the details of the product once it is released.
If you need any other testers I would be happy to volunteer 😀
B4 Arrival!
Sorry if the Title dragged you down here, but without wanting to upset anybody is there any kind of an ETA for the B4?
A while ago
The B4 was renamed the B5, and it came out earlier this year. The new B4 is still in the works, and will be a general crossover instead of a specific design for open baffles.
Before B4 was B5?
Hi Jon,
thanks for that information. I was not aware of the renaming, but as long as the expected B4 is a 2-way stereo active crossover (or can be paired to achieve this) then it is what I need.
The aim is (still) to bi-amp an NS100M and JBL 4343 speakers and I am in the embarrassing situation of having nearly all the bits assembled except for the piece that goes in the middle, the B4 (apparently ex-B5!).
Thanks again
George
Hi Jon,
Thanks again
George
B5
Hi George:
Just so you understand, the B5 is designed specifically for open baffle systems, primarily for use with a fullrange on top. The highest crossover frequency is 300 hz, and there is a bass boost around 40 hz to make up for the cancelation of low frequencies in an open baffle.
The B4 will be designed with a wider range of crossover frequencies, slopes from 6 db/octave to 24 db/octave, and no bass boost.
Hi George:
B4
Hi Jon,
thanks for that.
Yes, the B4 is exactly what I need for my projects.....perhaps in 2012?
George
Hi Jon,
thanks for that.
George
What about just using a pair of Pass Diy B1 Boards, selecting the appropriate value series capacitors on the board for high pass, and adding a shunt cap for low pass?
-Chas
-Chas
B4 Arrival!
I am still hanging on for a pair of B4's.
I am not sure if the modded B1 route would be the best if the B4 becomes vaporware. Maybe if I threaten to hold my breath papa might come through?
George
George
B4 availability
I personally believe this will be an extremely attractive design, giving users not only the ability to bi-amp, but also to rapidly prototype different crossover points and slopes. It should be on every speaker builders wish list. Yesterday I prototyped no less than 20 different crossovers on my speakers in the morning using an XVR-1 electronic crossover. The results were completely counter intuitive, with a different hi-pass and low-pass frequency giving the absolute best phase and frequency response. Try doing that with solder and discrete components. You probably would not even try different frequencies, or different slopes, unless you had a lot of patience and a huge parts bin.
The more people who state they want one, the more likely this project will be sped along. So if you are interested, speak up!
Speak Up!
That was useful information and very reassuring. I think the B4 is only a year or so behind schedule. I would like to be able to buy the kits before the Euro crashes over here. After that Papa is going to have to learn a bartering system 🙂
So, how can we apply a little (polite) pressure to get the kits going? How about a march on Pass Labs, banners and so on? Anyone?
George
George
Polite Pressure
I would just write a simple note, indicating that you believe this will be a great product, you need at least one, and you believe that others will be very interested as well. Get any friends who feel agree to do the same.
No banners or marching on Pass Labs. Too much work, and Nelson would spend time digging a mote and building defensive walls rather than finishing the B4.
When people start agitating for something, I take that as a sign that there
is no market for it. This is a philosophy that has served me well for the last
40 years.
40 years.
B4 production
Looks like the quiet treatment worked. B4's will be available towards the end of February.
Oh, Ok... we shall all be quiet and wait with bated breath...not a whisper shall be heard.
Keeping Quiet
That's great.. looks like a workable strategy for new projects too. Now what else do we need that we should keep quiet about? How about a Pass karaoke player?
Karaoke
I personally believe we should be very LOUD about a First Watt karaoke player just to make sure it never gets built. I sing like a bullfrog in heat.
- Pass Labs B4 crossover questions
