I realize that someone will mistake the Blazing Saddles clip for what I
posted.
For what I posted, go to FIRST WATT
posted.
OMG! This excites me the most:
from the SIT Nemesis article, "I have reason to believe that we will see some new SIT parts from a couple of sources in the coming year – parts that you should be able to actually buy.
You should probably start saving for them now..."
Giddy with joy!
Giddy with joy!
I will not be offering a kit, as there simply would be too much support
required. As it is, customers of B5 and B4 already require a lot of
hand holding.
hand holding.
so no DIY possible🙁I will not be offering a kit, as there simply would be too much support
hand holding.
.......a lot of
hand holding.
O Tempora ............ O Mores !
Thanks Nelson. Just about to start one of these based on Rollins article and this help connect a few dots.
hand holding.
Yeah. I am thinking of modding my B5 and I don't even have it yet.
Any reason i can't run the output of the filter directly into F5 FE vs through another buffer. I am starting on an F5T integrated for the bedroom and plan to have the XO double as pre. Did you get the switches from Digikey?
3 way crossover
I am looking for an electronic crossover to do the following:
low pass and high pass on midrange (330Hz and 2Khz)
high pass on tweeter (2Khz)
6db/oct slopes
I will need TWO B4s, correct? Will the sound quality degrade going through two B4's?
Thanks,
Herman
6db/oct slopes
Thanks,
Herman
- Pass Labs B4 crossover questions
