What can I build with +/- 60v rails?
Moderator
Joined 2010
Hello!
A buddy of mine gave me a pair of plate amps with very nice transformers in them, they are 49v-0-49v and probably 200-300VA each.
Can an Aleph or some other Papa amp be run on +/- 60v? Or is there something else to consider?
Are there any major disadvantages to this? (other than more expensive capacitors?)
I'd like to build an F4.......
Not to thread-jack, but I have a similar question.......
I have one of Nelson's toroids that he was giving away at BA2 (he showed up with a truckload of them).
It's got dual 0-115VAC primaries, and dual 45V/6.6A secondaries.
If I wired the primary in series to get 22.5V out of the secondaries, is that too much V for an F4 build? If it requires lots of mods, I'll just find a dual 18V 300-400VA transformer.....
60-0-60 is getting quite high for Class A - But still doable with huge heatsinks.
My Aleph 4 runs at 48-0-48 and does get QUITE WARM.
You might be able to produce an Aleph Turbo with 60-0-60V
Might be better to decide what you want to build and sell the traffos and buy the ones that you need.
