Joined 2002
As a professional musician I have to have gear that works ALL the time. I have a killer repair service near me. Every pot I've ever had to replace was replaced with a Noble... I've never replaced a Noble in anything. I concur... top quality.
I bought 2 for 50$ including shipping.
Ive use the relay type volume pots the digital ones the dacts etc etc the list goes on the LDR
ANd i always go back to the simple quality of a Noble
My dad alwasy taught me simple in simple out.
Chrisb on here made me a passive volume pot and a case, still have it and still use it till this day do i like it HELLS YES!!
Joined 2002
How about as a balance control?
why do you need balance ? i've yet to use one.
I like separate L/R volumes but balance is fine too. I've found that certain recordings need to be shifted just a tiny bit to really get that image to pop into place. I got hooked on Spica years ago and John Bau's grail was "sonic holography." Of course you can always shift yourself a bit. That said, I have no balance or separate L/R capability on my B1 and it is my reference front end. Dual mono stepped attenuator tracks right on. Any imbalance in a stereo pot is going to show up at the most attenuated positions, very low listening levels. Some, for example Audio Research, used to put in a general attenuator in front of the gain so the main pot could be operated in that 12:00 to 4:00 range... kind of a sweet spot.
Joined 2002
I like separate L/R volumes but balance is fine too. I've found that certain recordings need to be shifted just a tiny bit to really get that image to pop into place. I got hooked on Spica years ago and John Bau's grail was "sonic holography." Of course you can always shift yourself a bit. That said, I have no balance or separate L/R capability on my B1 and it is my reference front end. Dual mono stepped attenuator tracks right on. Any imbalance in a stereo pot is going to show up at the most attenuated positions, midnight listening levels. Some, for example Audio Research, used to put in a general attenuator in front of the gain so the main pot could be operated in that 12:00 to 4:00 range... kind of a sweet spot.
I use one pot,
Out from source, into pot ( b1 possibly ) then to power amp. Simple out Simple in.
No need for balance as I adjust to thinking it was meant to be louder / softer on one or other side..
try it one day, use a pot, and just make a passive volume control. you would be amazed on what you hear / notice.
Joined 2002
I'll give a try in a week or so... I have an ALPS and a few Nobles around... I'll wire 'em up!
post pics show us the rig and your thoughts
Wil do...
Question.
Do you listen through headphones most of the time?
Just my curious self asking/thinking etc.
bassnkeys
I will do that.post pics show us the rig and your thoughts
Question.
bassnkeys
Joined 2002
I will do that.
Question.
bassnkeys
nope, 2 speakers Planet10 & chrisb got me hooked on a pair of half-chilli speakers and i love them. Now to Finnish my alephs and hear there REAL potential.
J
Anyone has a good source for those Noble pots? Also 4 gang possibly?Try a noble
Thank you,
Eric
Joined 2002
Thank you,
Eric
ebay, it's a hit or miss,
Thank you,
Eric
I've got a four gang 10K LIN Noble Pot for sale.
Rod Elliot recommends using a LIN pot with a fixed resistor across it to improve on the non-linearity of a standard LOG pot.
http://sound.westhost.com/project01.htm
Joined 2002
Percy audio has them.
I was about to say the same thing but couldn't for 100% make sure it was them or not..
good company too..
thanks btw
Joined 2002
ESP - A Better Volume Control
that ^ noble would be the VERYBOTTOM of the list of good pots.
Oooooh Santa Claus has arrived
I feel like a Kiddie in a sweetie shop.
All my 10uF caps for the O/P for my B1 have arrived together.
From the Obbligato 10uF PIOs all the way through to the Chinese 10uF Audiophile Kondensor Caps.
It's got to be the Obbligatoes but they will take some re-work of the PCB to get them to fit. Not a problem but I don't want to destroy the PCB by having to rework it too many times.
Joined 2002
The leftovers will be available for a fraction of their cost.
Has anyone got any comments on the Jims Audio Yellow Drops?
The Chinese Audiophiller MKPS have been slated in previous posts.
shipping from you = 30 plus days X 3$ = not really worth it..
Plus you took to many pictures of them, they are de-valued now
LOL..
- B1 builders thread
