Yet another Volume controlers and source selections
TDA7439 ATMEGA8
Hi
Finish the test program for TDA7439
'ATMEGA8
'fusebit INT 8 Mhz
' LINK TO DATASHEET http://www.atmel.com/dyn/resources/prod_documents/doc2486.pdf
' ENCODER/BUTON
' Portd.0 MENU Button
' portD.1 Encoder B
' portD.2 Encoder A
' GND Encoder C
' LINK to DATASHEET http://www.sparkfun.com/datasheets/Components/TW-700198.pdf
' TDA7439
' SDA Pin 1 To Portc.4
' SCL Pin 30 To Portc.5
' 2 * 4K7 RES to pullup SDA & SCL to +5V
' LINK TO DATASHEET http://www.datasheetcatalog.org/datasheet/stmicroelectronics/4291.pdf
' LCD 16x2
' Rs = Portb.0
' E = Portb.1
' Db4 = Portb.2
' Db5 = Portb.3
' Db6 = Portb.4
' Db7 = Portb.5
' RW = GND
' Add a potmeter for contrast !!!
' FUNCTIONS
' INPUT 1 to 4
' VOLUME 0 to -56 db
' INPUT GAIN 0 to 15 db
' BASS -14 to +14 db
' MIDDLE -14 to +14 db
' TRIBLE -14 to +14 db
' MENU AUTO RESET TO MAIN menu (volume) after 3 sec
Video Here :
VIODE OF LCD MENU
Files Here :
HEX BIN for ATMEGA8 & schematic
ok
one thng can we change input 1 ... to some thing like CD, FM , USB DAC, Phone , phone as in cell phone.. for usb dac i was thinking sinc there is a pin on PCM2704 which changes state when connected to pc. than we can use that pin to check for connection to pc so no need to touch the dial for changing channel if we connect to pc
ok
Done 🙂 CD, FM , USB DAC, Phone and center menu select on lcd
Added Portd.3 as SSPND
activ = low (auto select USB DAC)
! Note you cant change input while PORTD.3 IS LOW
files are updated
it's the same board as you can buy from tibi.
turn the volume up, and disconnoct the source you will hear hum
Jempie,
There are two 0 ohm resistors on the board R42L and R42R.
These are connecting VC ground to VC power suppply ground.
Normally these resistors shouldn't be connected. However, we have provided them in case you want to make a single ground star for all power sources in your design.
If these resistor are not connected, than you should search for hum elsewhere, because in this case VC is completely isolated from any power supply.
Tibi
pcb layout for TDA7439DS
hi
made this pcb for replacing my pga2311 ( vvvvvvvery sweet chip) card, since things are modular in my amp.. i can relace the processor, amp, power filters. so even my preamp is sort of modular...
anyways just posting the pic of the pcb... let me how to improve it more.. if possible..
yes i know i should have used mkt capz.... but .... i wanted to make it small and couldnt source all the cap in same chemical family in bombay market.. anyways.. did what i could
Farmtech
According to the regular r2r schematic the resistors are
R30-R40
10k 2.5k 5.8k 15k 53k 390k
R31-R41
82k 47k 27k 16k 12k 10k
If you compare link Logarithmic Attenuator Calculator
The value are different
10k 8k2 5k6 3k9. I have the Same problem as jempie
