Mosfet amp, 5 pairs IRFP240/9240
All wiring is very easy ... 😎
Paul very nice work, but very many connections, and little cooling.
Really, Federmann? This amp gives 120W/ch and heatsink is 130x300x40 mm, while yours gives 500W/ch (how you declare) and heatsink is 150x400x40 mm...Which one of these has larger area for this nominal power dissipation? And connection: I am using for output 120W 2x2 16A WAGO, TWO IN PARALLEL, while you for 500W only 2x1pin, which have only 12A...What do you mean, which one connection will have higher reliability ?
I have any problems with cooling of this amp and many users too, Federmann...is funny, if you argue with cooling of bottom and upper cover, 'cos there is air circulation minimal and exchange of the heat into air will be only symbolic, particularly if you give him into the rack...
BTW, efficiency of cooling by these parts was demonstrate by your prototype of this amp, which was without heatsinks...
