Yet another Volume controlers and source selections
here are some pics of the dthing
Yes if you dont connect 7439
then it dont startup do to the I2C commands for init 7439
Found a error in trible so you have to get the files again from my server
added the new file into old zip 🙂
I see you used Cap for 7439 I plan to use WIMA cap for most
(0.47Uf & 2.2Uf)
here i will use mundorf mkp
this was trial board actuall board when all is done will have the box caps yellow colour box caps, the ones u showed are all dream caps for me,, if i were to get them it would be a nice hole in my pocket which would be like i m buying some low mid range Polk bookshelf speaker in india
FarmTech, yes i have check more then 10 times the components
there is no difference between schematic and board.
i use winstar WH1602L-TMI-ET display with no resistors on A-K for the blacklight
i use 14 V AC is this to high?
Well
14VAC = about 20Vdc
9VAC = about 12VDC
try a lower VAC I think thats why you have heating problems
see datasheet Page 4 Output Voltage
it show max 12VDC for high current use
