Anyone using PA(not PRO) comression drivers?
I want to have a single source for most of the F range. And what can be better at this than a compression driver.
How bad is to cross over at 6500hz? At the right moment a better driver will replace them..one that goes to 10000hz at least.
I used Monacor KU-516 with good results (Universe 3-way).
It's like having affordable coax driver (BMS, BC) without its phase fidelity. Such a large horn I would recommend use with 8"-12" midwoofer, 2 or 3 octaves above 80Hz with midrange-tweeter driver in smaller horn like here:
http://horns.pl/galeria/Zoltan_2.jpg
(supravox mid + radian tweeter)
plus distributed subs (eg. Rythmik Audio?). For me sound is relaxing and constant regardless of volume. Subjective opinions -> StudioSound
quoted from Fiesta 25 description:
As a special feature the Fiesta 25 comes equipped with a slightly altered DK 8 P 100 V/15 W midrange pressure chamber horn. The driver's characteristics between 500 and 5000 Hz were quite astonishing. Alteration of the driver is accomplished in no time and is described in our building instruction.
I would be curious to know what these modifications are.
Fun project for sure!
