My_Ref Fremen Edition - need help on PCB evaluation
I think you're right pointing out the lead free solder...
When TP boards were new the Zns leads mounted quite easily, after desoldering they don't fit unless you put some new solder in the empty hole and suck it with a vacuum pump.
Only after I've buyed a desoldering station I've managed to have those pads really clear... 😉
Obviously I've always used leaded solder.
On the MINI2496 I've used lead-free solder and the only way to have a clean pad after desoldering is to wet the void hole with leaded solder...
I'm confident that the 1.27mm holes will help us with 1.0mm leads. 🙂
To get the holes clean enough, normally the pad is heated too much, that is why my through hole came out on the power resistor.
I've desoldered several times quite all components on those PCBs and the only component that gave me problems were the big smoothing caps.
With leaded solder...
Anyway I think we're safe with 1,27mm holes, don't you?
Lead solders are much better to work with.😉
In perspective, if the TP used 1mm and now you use 1.27mm then I would say it is okay for the majority caps out there.
I would like to propose more room on the board for C4. Possible enough room to fit the 1uF cap provided by TP is enough. I tried changing C4 to the same type cap of 0.68uF, it seemed to work charms like I anticipated.
A 22mm cap? 😱
It's not possible, maybe I can squeeze in a 15mm LS cap (MKP4 0.68uF is available in 15mm) but decoupling effectiveness would probably be lower...
Soemething like the attached schematic but I've some doubts...
Every mm more between caps and LM3886 could be detrimental and/or reduce decoupling effectiveness...
15mm lead pitch is fine for C4 (with flexible lead-pitch options including 10, 7.5 and 5mm, all with one parts outline). In V1.4, I used 8x multifilar traces on both layers between C4 and the LM3886 power pins, but one thick stripline trace over a ground plane will also be fine.
Siva, the flexible lead pitch cap you're using is in a public library? If so how it's called?
Payment collection
Since I don't want the Fremen Edition to be an endless work I've finalyzed the beta layout (attached) for production.
I'm waiting payment confirmation from the fourth participant, BTW I'l cover the extra cost if he pulls back so the import will be 29€ + shipping.
If the packet is less than 350g, shipping by Registered Mail will be:
Europe 9.50€
Worldwide (except Oceania) 12.50€
Add 4.50€ to have included 6 hard to find Elna RJH 220uF 50V, BAV99 and ZMY27.
Each participant should PM me with his PayPal account so I can send him the PayPal Invoice.
Thanks 🙂
Our local VAT is 5%. Normally buying through the web, not VAT is incurred. I wonder how it works in other places.
Here in the European Union we must always pay VAT.
When ordering from another EU country we pay the VAT of that country (which can be slightly different but always around 20%), if the order is made outside EU we pay local (our) VAT and in most cases also customs duties.
