OK chaps, I've done the search to death and can't find anything to be honest ...
I'm not a complete novice with speaker builds but design is a weakness and I've never tried a sub.
What I'm looking to make is a powered sub for LFE on a 5.1 system.
I'd like to have it behind the settee right up against the wall behind us.
Problem is that the gap is only 6"... height and width are not an issue but anything front firing would probably be useless although there is a gap about 6" wide down the side under the curve of the couch arms.
I have built everything else... decoder, amp, FR front & rear speakers and it sounds really good, just needs that little more ooomph on the special effects.
I need some help here guys.
Cheers
Lee
Cheers
Lee
As you know, this is really constraining driver size. Within your size limits, 2 Dayton ND105-4 (wired in series) in 16 liters net and tuned to 47 Hz will give F3/F10 at 42/36 Hz. 100dB w/ 15 watts. These drivers provide amazing bass for their size. You will be output/excursion limited with these drivers. They are robust and can survive excursions to their mechanical limits (~10 mm)
You would get higher efficiency w/ a pair of ND105-8's wired in parallel, but I haven't measured the specs on those drivers. I do know that the factory specs are off by more than the usual on the ND104s.
I can help w/ box design and vent sizing if you'd like.
Cheers
Lee
Cheers
Lee
Hi, Here is a very slim sub(<5.5 inch) suggestion I recommend you to build(a couple of? ) that fits your narrow space :
b🙂
Hmm this sounds like it will certainly fit the size restrictions and those drivers are a temping price, nice suggestion fastbike.
I need to do some sketching me thinks......
b🙂
Woa😎 they are lovely..... what height are they?
I could make those no problem..... I'll give that thread a good read tonight
Thanks for the pointer bjorno🙂
How is the output with such a small mouth (hole) on that ?
Hi mRgSr,
A good question: If you compare a T-TQWT_T-QWP with a 4:th order BP using the same port-area and same fb tuning:
The Lp filtering action of the port and airways return path is much more effective than the single ported front (echo🙄)chamber of a BP.
The BP will sound much worse(off-band leak effects) at x-max due to no damping material in front of the driver, normally only in the closed chamber.
Further, The BP driver sees the port area that usually is >= Sd/3 considered= OK.
Unlike the BP,the T-TQWT/ T-QWP is loaded at the driver front by at least twice of this area, whereas one half is always LP filtered by the damping material in use.
IMO the SQ at x-max is second to none if compared with a corresponding 4:th order BP.
Port noise?, I never herd that from a T-TQWT as I always play my subs well below x-max and if I need more SPL I just add another one.
b🙂
Ps:
The size of the port shown in the pictures here-above is ~3" and the compression rato~(2.94:1).
IME: When sitting at a coach 'hugging' a newly built T-TQWT placed next to you and hooked up to your Stereo, you be surprised of the low FR end SQ now appearing from your main speakers and have no localization effect from the sub if the T-TQWT port is pointed away form your own body.
Slightly wider than you might want, but the tapped horns linked in my signature do a decent job of special effects. They're just over 7" wide, but they are really really good - I've tried them with movies like the Dark Knight, and I just kept turning it up louder and louder.
I used a pair of them with a pair of 12" coaxials in a rather big room (20m by 10m), playing It's Oh So Quiet by Bjork (has some low stuff on a double bass), and they kept up fine. The 12"s had about 10w per side (98dB@1w), and the tapped horns more like 150w.
Highly recommended.
Chris
Highly recommended.
Chris
The external height is ~48" or 122 cm. The box dimensions are (LxWxD)=
48" x 8.27" x 5.32" or (122cm x 21cm x 13.5cm).
I've posted this design somewhere here at Sub-woofer's earlier: Simulations and real measurements included .but cannot find the thread(s).🙁
b🙂
Highly recommended.
Chris
Hi Chris, they look fantastic, I can't believe the guy has 4 in his bedroom😱 It might be a bit of a squeeze, although I could shuffle the dimensions a bit and put the port to the side.... Hmmm🙄
Hi bjorno, that's going to be too high I think... Very low WAF factor🙁The external height is ~48" or 122 cm. The box dimensions are (LxWxD)=
b🙂
I could probably put one or even two laid sideways though with the port low down..... might be a solution....
Why consider placing the T-TQWT upright? There in no reason for the T-TQWT's to be 'WAF' visible for anyone. Just hide the sub(s) anywhere in the room preferably not all occupying the same location.
It is the solution.
Unlike a TH you can clog the port until the free air area is about the port area. i.e. the suggested T-TQWT port can be oriented pointing at a wall or other object as close as ~1.9 cm without changing sound character.
The T-TQWT is a pressure point source and not much depending on external boundary load influences,
unlike a TH that will change the appearance of sound character if operating into a restricting CSA as terminating area must expand into a larger air path without a narrowing boundary if not to be totally detuned.
b 🙂
It is the solution.
b 🙂
Indeed 🙂
This one is high on the list at the moment
When did you post it? It can be searched......
Indeed 🙂
I guess within 3 years and I'm not sure, the T-TQWT could been labeled = a BP-TQWT?
b🙂
Hi bjorno,
Could the port be relocated sideways, e.g.: as a slot port instead of a circle?
Hope you find the respective design.
Hi bjorno,
Hi Oliver,
That's a good idea, I've only tested this approach once but it should work, even better than a circular port opening I made that will perform better if placed as 'low' as possible.
Two (square-like) slot like ports(area= S4/2) placed as low as possible on each of the sideways would surely work well too.
b🙂
This might interest you
http://partsexpressinternational.ugc.bazaarvoice.com/stories/2444-en_us/34356/photo.jpg
Home Subwoofer Projects Created By Parts Express Customers, Home Theater Subwoofer Designs, Material Selection, Enclosure Assembly, Home Audio/Video Subwoofer Projects, DIY Home Theater
It's only about 5 -6 inches thick.
It's a Parts Express project. The Boogieman.http://partsexpressinternational.ugc.bazaarvoice.com/stories/2444-en_us/34356/photo.jpg
An externally hosted image should be here but it was not working when we last tested it.It's a Parts Express project. The Boogieman.
Pretty cool.... but too rich for my budget that one 😎
Maybe when the TB's were much cheaper but @ $100 each....
- Subwoofers
- Advice on 'slimline' sub..... please
