3-Way Crossover Assistance Request.
I have currently a very rudimentary 2nd order LW-R 3 way crossover design in my speakers. It has no attenuation to account for variables in the sensitivity, nor do I believe the crossover points to be optimally placed.
My goal:
I want to redefine the crossover starting from scratch to make my mid-bass and mid range more prominent, and tone down my Woofer and Tweeter. I also plan on increasing the crossover points by a fair margin since my cabinet design shifted significantly since I originally created the crossovers and it allows me more wiggle room with the implementation.
Current Data:
Tweeter Data Page: ScanSpeak Discovery D2608/9130 1" Textile Dome HDS Tweeter: Madisound Speaker Store
Midrange Data Page: Scanspeak Discovery 10F/8424G 4" Midrange 8 ohm: Madisound Speaker Store
Woofer Data Page: Scanspeak 22W/8534G Discovery 8" Woofer: Madisound Speaker Store
I am thinking of lowering the overall sensitivity to around 85db and leaving the midrange without any attenuation to make it more prominent.
I was also thinking that according to the spec sheets I might set my crossover points at 5khz and 900-1khz. Any information would be greatly appreciated, as well as input into design and development.
For those that might need the information about the cabinetry here is the link for the building photobook: http://photobucket.com/IstocsCustomCabinets
The password is: DIYAudio
As it can be seen I deep set the drivers.
Hi Istoc, It's very hard (for me) to say without seeing measurements on your actual baffles. You really don't want to attenuate the bass driver if you can avoid it.
Have you considered going active for the bass crossover and passive on the MT crossover? This will allow line level adjustment. That's my plan, though I haven't implemented it yet so can't vouch from experience.
Looking at the FR curve of the mid part of the problem may be the rising response after a bit less than 1k. If you are using plain old 2nd order electrical your acoustic slope will probably not be what you want/expect and this may be compounding problems with the higher frequencies.
It's quite easy to add an Lpad on the tweeter, this should probably be your first step. Due to baffle step the bass may be less of an issue. If you can take measurements though that will give you the best chance of working out what the best option is.
Tony.
I already read through that posting, actually I contacted Allen directly to see if I could get his assistance. I would do measurements if I had equipment to do so, also I don't run any external amplification so until/if I do Active Crossover networks are kind of out of my area. Honestly the bass drivers presence is fine, it very rarely makes itself more noticeable in the speaker layout blending fairly well. Its more the fact I want to see if its possible to make the mid range more present because at this time its seriously lacking. I don't believe its a driver issue or I would probably just modify the opening and use a different similar driver(perhaps larger). I think it has to do with it being quite a substantial bit lower in sensitivity in comparison to the other two drivers in such close proximity. Sorry about the wall of text I'm using quick reply.
I
(senior noobie inside talkin' 😱)
I always see Dave-Planet 10 that dislikes the use of domes , especially in the critical area around 1 KHz ; Also, that frequency was used in the past ( and still nowadays ) when crossing from a 15" to a 1"or 2" compression driver , but that's another story . So I don't see a good use for a big cone ( a cone midrange compared to a dome or planar ) starting from there .
Often , the mid needs to be attenuated in a 3 way .
What Tony said , to go active , might be a kick start for expanding dynamics and also playing with different points / slopes , I think that's fun !
Hi Istoc, I think we need to establish what you currently have crossover wise. When you say rudimentary 2nd order L/R do you mean as per a stock crossover calculated for a particular frequency and impedance?
Do you have any impedance compensation on the drivers?
I suspect that there is a bit more going on than level adjustments alone will fix, but I am assuming that you only have theoretical 2nd order L/R electrical filters. How that electrical filter interacts with the driver and resulting acoustic slope of the crossover is what actually matters.
You may also want to check out Daves guide for designing without measurements software right at the bottom of the page). His guide steps you through using various free software to get spl and impedance curves and the use of Passive crossover designer for simulating the crossovers.
It would be worth while doing this and putting your current crossover into the sim just to see what the sim thinks will be the result. It might surprise you! 🙂 I am of course assuming that you haven't done so already....
One other question as well. Have you tried inverting the mid drivers polarity?
Tony.
I have no outside Impedence correction, other than what the Inductor and Capacitor in line would equate to which when I checked was almost a nil value. I'll most definitely read his information as well, I can easily swap the polarity and see if it becomes more clear. I will have to follow up more on this later today as its time for me to head to work. I'll check in every couple hours at work to see if there are updates here though.
The crossover design was purely speculatory according to online calculators to be at certain frequencies. I spoke with Wolf while I was making them and followed some of his instruction to verify the values were accurate. At this time the values I used for crossing over are escaping me although I'll try my best to find the current values relative to hz.
Also anything to do with excell I'll have to use Google Docs I don't own anything microsoft, I'm using a student copy of Windows 7 I got when I was taking IT classes. Will most of the stuff respond in google docs do you think?
(hi !!)
The fact is that our assumptions are made by seeing the photos ,and I see two 7 mH inductors and about 50/100 µF caps . Working with the values you have on hand -just for fun...- you can try to skip the inductance on the midrange after the cap ,maybe place it on the woofer to obtain 14 mH , and double the cap in the HP section . The mid needs to be in anti-phase . And you may try to lift the upper cabinet about 15-20 cm and use 1st order filters between wf and mid . Also a reflex port would change the presence of the mid .
Without being able to measure, you will face limitations. Still, when you post your crossover you ought to get some suggestions for changing it. As for Wintermute, my first assumption might be that impedance compensation would give you more control and probably improve things.
Accuracy of component values is not going to be a significant issue just yet.
Just the component values (as a schematic) will be fine.
I had to pull the bottom off the speakers to get the values again. I lost my old notes on the values used. The current crossover are as follows:
Tweeter: 3.6uF .91mH
Midrange: Just one of the high pass and low pass
Woofer: 27.0uF 7.0mH
The first thing to do IMO is fully model what you currently have.
(Model the mid diffraction as though its cabinet is much taller,
this will give you results nearer to the way the mids are placed.)
FWIW I reckon modelling will likely indicate the issues you have.
FWIW your 89dB bass driver is suited to a speaker of about 85dB
(maybe 84dB), once baffle step is configured in, it seems to me
most likely your issues are a depressed low midrange, relative to
a rising upper midrange and treble.
rgds, sreten.
What is FWIW? As i focused on listening to my speakers I noticed that nearly as much vocal was coming through my tweeter as midrange.
According to my calculators the frequencies are 2760 and 365. The low crossover is perhaps a but too low for the midrange.
FWIW = for what its worth.
With an overall sensible target of 85dB with that bass driver for a 3 way
your tweeters are running +6dB too hot, and likely the baffle step of
the midrange is uncompensated, skewing the sound towards the treble.
The drivers should make an excellent 3-way, with the right crossover.
AFAICT (as far as I can tell) you need to implement some of the baffle
step on the midrange driver, bring it down to ~ 85dB and some of the
baffle step with some subtle bass to mid overlap, you need to model.
See this link where all mid BSC is implemented by bass / mid overlap :
http://www.deadwaxcafe.com/vzone/david/david.htm
rgds, sreten.
Ok I can help 😉
It is a starting point, you need measurements to design a precise crossover.
You are lucky because textbook values could work in this case.
Buy four LPAD and follow the schema below. The LDAP are represented by Rs2/Rp2 and Rs4/Rp4.
I keep your values but you need to attenuate a lot more the mid and the tweeter ! Full bass step compensation here Sensitivity = 82dB.
Note the midrange is connected in opposite polarity 😉
If you do the recommendations, suppress L4 and listen if it is better.
Let us know it works 😉
Ok I can help 😉
No. If you don't model it properly you are simply guessing, as this is.
It won't work up to capabilities of the drivers and is wrong in many respects.
For a start you've assumed an 8 ohm mid driver when it is actually 4 ohms.
It is not the way to design a speaker with expensive drivers, I've posted
links with details of how to do that, and there is no other way of doing
it properly, the acoustic effects of the cabinets must be included.
rgds, sreten.
Expensive or not , it is the target that you want to acquire .
That was the only way to make less shouty an Audax PR17MO .
The woofer was a late seventies Altec clone made by Kenwood.
But I dismantled the gigantic boxes 1 month ago.
Now the woofers runs in OB , well , just a frame 🙂
in 3 way+rear tw , and the mids and tweeters are super -budget
Well they are nothing like the OP's speakers,
remotely. So what is the practical relevance ?
rgds, sreten.
