Does that mean you want our fusing recommendation for that Rcore transformer?
Tell us the input power rating. Or ask the retailer.
I asked the retailer.
yeah it should be fine, the primary should be pulling just a fraction over that at full tilt, I'd rather be a little on the safe side as the fuse can last several seconds to minutes at its rated current.
Input power rating full load is aprox 33VA.
Close rated fusing is 33VA/220Vac ~ T200mA
Normal nuisance resistant direct on line starting fuse rating is 3*33Vac/220Vac ~ T500mA
not that in this case matters, but its' divided by 230 in Spain 🙂
- Power Supplies
- Fuse for 5V 1A
