Vtl 750
Hi
I found a solution with other VTL amps using the trafo Sowter 3575, it is a 1:1+1 10Kohm.
You can connect in balance mode the primary and in unbal the secondary to the amp input.
Normally I put it inside the amp close to Rca input; normally a old VTL amps have a hole for XLR .
bye
Walter
