Hello,
can anybody help with information of the Balanced Input Stage of this amplifier. Like to convert an older model from SE to balanced input.
In the VTL book is only the SE version.
Thank you,
Reinhard
Thank you,
Reinhard
Hi
I found a solution with other VTL amps using the trafo Sowter 3575, it is a 1:1+1 10Kohm.
You can connect in balance mode the primary and in unbal the secondary to the amp input.
Normally I put it inside the amp close to Rca input; normally a old VTL amps have a hole for XLR .
bye
Walter
bye
Walter
Walter,
thank you for the information, but I am still looking for the original balanced input,
Reinhard
Reinhard
Hello,
Thank you,
Reinhard
I have the drawings for the balanced input of the VTL750. Still need them?
do you have a scan to send?
Reinhard
Sure, I have it in autocad. Can send you a pdf to you personal e-mail.
Hi Palmas, could you please send me the pdf, too?
marcello.pellerano@libero.it
Thank you!
Marcello
- Tubes / Valves
- Vtl 750
