Glad to be at your service.Hello Fred,
Envelope arrived in good shape.
Many thanks.
WK
Enjoy!!
My pleasure and glad to hear the safe arrival.Fred
The package arrived and in good shape. Thank you for the work and time you invested into this.
Best wishes, Kovax
Enjoy!!
Hi there,This the first I,ve seen this thread. I have an F5X case on order. Can I still get in on this group buy?
One member back out of the GB, so I do have extra mosfet sets and TO-220 pads; however, I can only spare 8 x TO-247 pads. Let me know the quantity that you want, I will let you know how much I can fulfill.
Notice that I am the US case distributor, I know when you will need these parts
Thanks!!
Triode4,
At this moment in time, you do not need any for F5X. (You may still, if you want.)
You might in the future, when I work out the regulator thermal solution and the test team gives a definitely comparison between CRC and CRegC, and you then decide to go to CRegC from CRC.
Please see :
http://www.diyaudio.com/forums/grou...e-user-distribution-check-12.html#post2795335
(Post #580 onwards...)
Patrick
Please see :
Patrick
8 TO-247 are all I have left for the moment. You probably want some TO-220 as well.
I will put aside of Keratherm pads for you. I have added you to the spreadsheet, column O is total.
While shipping of these only cost a stamp, I will send these along with the case unless you insist. If later on, you want a set of the mosfets, just let me know.
Thanks!!
Thanks!!
- Group Buys
- GB 2SK3497/2SJ618 for EUVL F5X or other projects
