Class D Amp with LM566, LM393 and 2XIRF530
Output stage with IR2111 driver
There are often issues with discrete class d amplifiers.
I have built my own design and seen a few others and i now stick to the irs2092.
The 2092 takes care of clipping and feedback better than a discrete solution.
If you arent going to push the map hard then a discrete class d amp might be fine, if you are going to push it hard then I would avoid discrete cass d.
