sonix said:
I found that even the output power of the 45 tube in SE mode is only 1.5W, it has the advantage over the 2A3 and 300B because its idle current is only 30-35mA. I built two 45 amps with LL1620 and LL1620AM which is specified to work at 30mA. According to the datasheet, the primary inductance almost 100H. Most of the SE OPT for 2A3 and 300B are with approx 24-30H primary inductance.
After listening to these two amps in about 2 months time, I noticed that its bass response is excellent.
My friend just bought the Yamamoto 45 amp. I would really like to hear it to see what are the differences between Yamamoto and mine. BTW, my 45 amps are using 6SN7 for the driver which is the design from Sun Audio's 2A3 SE amp.
Johnny
Am I the only one here that finds this schematic not compelling?
Unbypassed zener string, Pentode driving a triode, ewwwww! Ok, the transformers and the cherry wood and the finish are sexy, but it really looks like somethinh an amateur would design. (How am I going to drive the DHT, it needs a lot of voltage! Oh! I ll just stisck a Pentode it has all this nice voltage gain!!!!)
costis_n: "Pentode driving a triode, ewwwww!"
What's wrong with using pentode? Have you listened to it or an amp using pentode driving a triode? Didn't the Western Electric 91 use the same thing? If designed right, I don't see any reason to object to it.
Konnichiwa,
I have decided to post the Schematic in another on-line group with pretty complete detail, so also find it here, in context. It is basically 99%, one or two values may be slightly different, but not much.
If you want to copy the Amplifier you do of course need the iron, considering fit/finish, component quality and inclusion of NOS Valves I'd think it's worth giving Yamamoto the business and buying the Kit if you want to build the Amplifier, a Set of Tamura Transformers and a nice case plus the valves will take most of the cost of the kit.... ;-)
Sayonara
I need it also...Can someone post details with original shematic and parts list (also from which manufacturer are parts exactly). It would be a great help, not just for me i think...Big thanks in advance...
