new batch of mini Aleph amplifier and PSU boards
Brian, I just pay paled you for a set of the power supply board and a set of the amp boards. I assume this is a stereo set? it occurred to me I usually build dual mono, do I need to pay for another PS board, or is the one sufficient for a stereo amp, on the same chassis of course.
Lastly, is there a BOM anywhere?
Thanks for the opportunity to build this.
Russellc
on the website!
F5 from Brians pcb's
Has anyone built a F5 based on these boards ? If so could you please post the details and/or a simple stuffing guide ? The mini-A is a little to small for ineffiecent speakers where the F5 may be just right ! I'm basically looking for something with a little more power but wont break the bank building it ! Any help would be greatily appreciated Thank's !😕
Udaily Thank's: I realize that one can use the output boards ect ... but after looking at some of the F5 stuff I've seen it using 2) Irf240's thus not needing additianal componets. Also Hoping to use smaller heatsink's and transformer.
I am building an mono block Aleph J with brian's boards and had a question about the psu boards. Is there a way I can wire it to use all six caps for just one channel to take advantage of more filtering? Why would you not use R3-R12 and take advantage of less ripple?
The power supply has 3 caps per rail. You have a + rail and - rail. Each channel needs power from the + rail and - rail to operate.
The three caps per side are not for each channel.
If you are making monoblocks, you will need two power supply boards.
You can add the resistors to get the CRC filtering, but just be sure they are the correct wattage
