I used 5 cent coins in my amp 🙂. You can see one in the upper right corner
I've been using pre-1982 US pennies. 95% copper and cheap. Drill with a #30 drill bit and use a #4 screw (a 1/8th bit works too).
It might be legal if:
You do it with coins of non-local currency at your home country.
Or, sent your coins oversea and ask others to do it for you.
Warning! This is not a legal advise.
That is a good idea. The world is flat anyway. Also, or even more so, overseas.
LOL 🙂
albert
Norway provides the holes ready made !!!
The 1, 2 and 5 crowns, seems to fit all sizes of TO-housing. 😀
Actually, the smallest heatsink pf tha to220 fit perfectli on the to247 front. I use them instead of the washers.
D.
D.
No, no, no, those are all too wimpy!
What you want is some mild steel bar:
Or copper
You think you've somehow gotten some magical copper alloy that is stronger than steel? (Are you challenging me to a peeing contest? Cuz I just had a large cup of tea...)
Actually some brasses are stronger than some steels! But normal brass is about 80% the strength of steel.
And some steel is waay stronger than brass.
Andersonics.
No ******* contest at all steel is much stronger than cooper.
Cooper just moves heath faster. and I was thinking about Nikon Idea to use a heath sink worth a try
It just needs to be strong enough not to crack the plastic bodies it is clamping.
Then one would argue about the magnetic proprieties of steel but I am not here to do that.
I would be in truble then as I am using Granite as front pannels.
Either way me think that 2 screws are beter than one especially as one would not need to use the tiny little screw to go trough the hole of the mosfet (M3 in metric) but can go larger (I am using M4 bolts with the heads buried in the spreaders)
So far I have not stripped the tread on any of those.
Has any body ever stripped a tread while bolting a mosfet to the Aluminium heath sinks?
So really the Idea to use Steel bar is a fine one indeed.
Especially if one use the Kerafoll stuff that improve in performance with increased pressure.
About the tea bit I just had half a bottle of Grappa so you win again if you go for quantity or distance I get the points for flamaleability
I was already bracing myself, wondering who would be the first to bring this up. Touché!Then one would argue about the magnetic proprieties of steel but I am not here to do that.
- Big A** Nelson Washers
