Tube line-buffer for cd
Hello outthere,
I am a newbie on diy tube gear, but recently finished a push/pull diy kit using plitron output transformers and svetlana tubes (6n1p driver / kt-88 output) .
Until now it has a pot for volume adjustment (passive pre)
Because i have some parts left (elma 24 stepped att. and some 6n1p / 6922 / ecc88 tubes) a simple pre/line driver with low gain (max 4 or so) would be nice to give the amp some more juice.
Does anyone have a schematic i can use for building such a line buffer?? Preferably with low or no overall feedback at all??
Thanx,
Sander
Check out the schematic I posted here. (the one at the end) I haven't actually built this yet, but it is a line buffer with a gain of 2.
As shown it is balanced input, but if you ground the inverting input and make your connection to the non-inverting input it will work fine single ended.
Decreasing the value of the degeneration resistors will increase the gain.
Hello Bas Horneman.
I am new in tube design, and I like to make a line amp capable of driving the Nelson Pass's Aleph 60 i have built.
I looked at your design (6n1p pre) , but I am not sure if it is a proper line stage for the mentioned amp.
The Aleph has a 48K input impedance, and is a DC couppled MOSFET class a design.
Also if you would be so kind specifying the in/output impedance, and gain.
Thanks,
Miki.
Hallo Miki,
Unfortunately I am an amateur and do not know how to calculate output impedance, gain etc.
What I would do is post and ask other diy'ers what they use with their Aleph 60..
What I do know is that the pre I once built..the 6n1p.. sounded quite good and is simple to make...
But how about the Bride of Zen pre amp also designed by Nelson Pass apparently it is a little beauty...
Thanks for your reply.
I heard once my Aleph with a tube preamp (a friend of mine lend to me for a few days...) and I was really impressed by the sound.
I have tried transistor/mostfet preamps, but I think that they performed worst.
And after all i'd like to see something GLOWING in my room 🙂))
By the way, today I started to learn tube circuit theory, and soon I will be able to calculate myself the requested values 🙂)
Thanks again,
regards,
Miki.
Hello again,
I read at your web page, that you had problems with the hum in the preamp, caused by non-groundig the heater circuit. How has to be grounded? Just put one of the transformer's 6.3V output to the ground? Or with a cap?
Thanks,
Miki.
Hi Miki,
Take 2 ..100ohm resistors.. solder to both legs of the 6,3 supply..
the 2 resistors then are both grounded..see picture.
Or get a centre tapped transformer...3,15v - 0 - 3,15v and ground the 0 volt tap. The3,15volt taps go to the heater of the tube
bas horneman the output impedance of the design u made is quite high common for this design
also i feel u shouldnot use both of the plates. Normally the plates are not match 100% they could be 51% left plate 49* right plate this cause imbalance
try using cathode follower output impedance is lower
i will try to get a schematic to further support this statement
NickC
What about an SRPP!
That lowers the output impedance quiet well! The only thing, I am confused with the SRPP, that I read somewhere that it is not recommended to run it as a lineamp stage (maybe the problem is with the load-dependent gain).
A question about Mr. Bas Horneman's design:
Could be done somehow to lower the otput impedance and the gain eather? (It's a little selfish "request", because I need a lower impedance and 6 - max 10 gain line stage) 🙂
thanks,
Miki.
Hello, all tube guru's 🙂
I just received two Phillips e88cc tubes, and I wonder if could be used in the Pat's preamp. I do not need so much gain so I would leave out the cathode cap.
Thank you,
Miki.
Pat's amp:
deja vu
Am I crazy, or have we seen this entire thread repeat twice before just in the last month???!!?
"I want a simple preamp."
"Ok, how about passive?" --> "Too high output impedance."
"How about a cathode follower?" ---> "Cathode followers sound bad."
"I know, what about SRPP???!!!" ---> "Yes, that's it!"
"Look, here's 'Pat's Super Awesome SRPP Preamp'!"
"Not enough gain!"
"You don't need gain!"
etc. etc. etc.:dead:
