shielding will get you closer to god.
Try some ferrite's on you twisted pair power supply cables and line in cables and if it helps you have got a hint of your problem. The large ones that samwhich over ac leads. If you want trick filtered ac leads get thick ac home twin and earth. Strip it and weave it macramé style. Works great. Straight out of Allen wrights cable cook book . God rest his soul.
Want to try somthing trick on ac input sheilding. I cant stress how important sheilding and rf filtering is with digital.
http://www.dhtrob.com/schemas/afbeeldingen/Cinch.gif This is somthing I am about to try.
I'm working on a Power Board with filtering.
There are plenty of people who don't have my problem, I'm not sure if its the configuration I am using. I'll build the filter & then see how I go.
I'm making one of these http://lampizator.eu/AC FILTER/SILK/FILTER.HTMLhttp://lampizator.eu/AC
It might be worth running minidsp off a 12 V battery just to see if mains born interference is a problem (before going to the trouble of building a filter - no doubt that design is very effective).
I thought i had nose issues with miniDSP balanced. Ran it off a 12V car battery yesterday (in the house). No change to noise. However connecting up a rather expensive pre-amp for comparison i'd have to say miniDSP sounded essentially the same in terms of noise, so not that bad. The noise needs about 15 dB of attenuation before it is acceptable via a power amp with 38x voltage gain into 101dB ribbon tweeter.
I have managed to get rid of a high pitched squeal (very very quiet), not sure how.
I like the 12V battery idea, will give that a go. I already have all the parts for the filter so will build it anyway
That 15db attenuation is on the DSP outputs I assume
Can someone tell me if EXACTLY the miniDSP Balanced Kit US$125 is in the miniDSP Balanced 2x4 US$145 ? Because the docs are different (e.a. no volume pot, no I2S on the second one) . I think this is only because of the enclosure, but if the pins are in there i can drill a hole for the volume pot.
For the project i want to build (digital amplifier with miniDSP in the same enclosure) it is maybe better to use the second miniDSP with a closed aluminium enclosure to avoid EMC troubles ?
FWIW, I ran a little measurement test with my TAD TD-4001s. I use a ATI 602 amp, its the best comercial amp I have found wrt to SNR and it has gain control on the back.
Ignore the dB Scale, I never calibarted the exact voltage levels in ARTA (think of 120dB on it as really 90dB). The MiniDSP does not really effect the signal chain that much. The DCX definitely increases the output by around +6dB and also increases distortion levels.
TAD + ATI 602
![TAD_NO_DSP.gif TAD_NO_DSP.gif](https://www.diyaudio.com/community/data/attachments/221/221329-63b296540999f14849fc54c2faba8945.jpg)
TAD + MINIdsp (unbalanced) + AT 602
![TAD_minidsp.gif TAD_minidsp.gif](https://www.diyaudio.com/community/data/attachments/221/221336-c5d74fdb1afb490b364d12039173d800.jpg)
and for reference of with the popular DCX
TAD + DCX + AT 602
![TAD_DCX.gif TAD_DCX.gif](https://www.diyaudio.com/community/data/attachments/221/221342-d3acae926e6f948a557e76768ebc5312.jpg)
@ katarakt
The miniDSP balanced 2x4 in a box is indeed the exact same board as the miniDSP balanced kit. It's just in a box.
So providing you drill the front panel, I guess that you could indeed upgrade it to a version with a volume pot with ease.
Hope this helps.
DevTeam
Hope this helps.
DevTeam
np, I have always been curious about the differences between the DCX and MiniDSP. I have always had gain issues and an excessive amount of hiss when using the DCX and 110dB CDs. The miniDSP made definitely more manageable.
Now can you please "somehow" add linear phase filters !!!
Im about to spend $2K on the DEQX but before I do that I want to give you a chance to have more of my $$$ ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
You can do linear-phase filters with the miniDSP. Use it to create a first-order acoustic, or maybe a filler-driver second-order, or etc. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Seriously though, linear-phase filters might be handy, but they shouldn't be near the top of miniDSP's development to-do list.
Dave.
Dave.
I didn't know MiniDSP can do LP filters, I still can not see how it can actually.
either way, I think everyone should like MiniDSP decide what is important on the to-do list.
Besides that, I say lets put up $$$ in front of our wishlist items. I have $2K to send to MiniDSP to help them decide what is more important
I wouldnt be the first time someone buys a spot at the front of the line. Its the way the real world works ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
NOTE J/K......Im using the $2K to buy the DEQX.
Fellas,
There are different types of linear-phase crossovers.
First-order acoustic, second-order filler driver, and a few others are linear-phase results that can be created in the analog world. Since the miniDSP generates filter responses that are identical to analog equivalents, it can achieve those objectives.
Now, if you desire an eighth-order Linkwitz-Riley result, then you can't there with the miniDSP......as currently offered.
However, if this (lack of) capability is a show-stopper for you then by all means spend the big bucks on a DEQX (or similar) solution.
The are lots of opinions on whether linear-phase crossovers bring enough/any advantages to the final product to warrant the cost/complexity. Unfortunately, most folks have never evaluated linear-phase and non-linear-phase solutions in a true apples-to-apples comparison.
Dave.
Dave.
@ katarakt
The miniDSP balanced 2x4 in a box is indeed the exact same board as the miniDSP balanced kit. It's just in a box.![]()
Hope this helps.
DevTeam
I've just overflown your answer, what a shame
I'm going to order one soon, excellent and fast service here, thanks a lot
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
...and for the normal 2x4 balanced kit too? So i can replace the optional volume control pot with a CT2-10k-1/fine with 0.5dB steps ?
edit: ...this thing costs 140,60 € !!! I'll stay with the normal pot
Fellas,
There are different types of linear-phase crossovers.First-order acoustic, second-order filler driver, and a few others are linear-phase results that can be created in the analog world. Since the miniDSP generates filter responses that are identical to analog equivalents, it can achieve those objectives.
Now, if you desire an eighth-order Linkwitz-Riley result, then you can't there with the miniDSP......as currently offered.However, if this (lack of) capability is a show-stopper for you then by all means spend the big bucks on a DEQX (or similar) solution.
Dave.
Many people also tend to forget that loudspeaker drivers themselves are very rarely linear phase themselves, so to get a true linear phase output you will have to use a non-phase linear crossover.
Would the 2x8 benefit from a stepped attenuator like the DACT CT2 in place of the optional volume control pot?
I believe the volume control pot doesn't carry an audio signal but is just a simple control for digital gain, so no need for audio jewellery here.
I had a hunch this was the case. Thanks!
