Photo Gallery
That's the source.
At 9kg, it's certainly substantial.
"Temporarily out of stock".
AL-470R-S Full Aluminium chassis Round corner Large Power amplifier - Silver color version
# Custom made R30mm corner section
# 10mm thick front, rear and side plates
# One long side plate (Front or Rear) thinner to 1.5mm for easy custom opening
# 4.5mm thick top and bottom plate offer very excellent strength and still easy for custom made opening
# Made in China
# Weight :8950 (gram/Each)
# Size (mm): 470 x 320 x 80
Item No: AL-470R-S
--Temporary Out-of-stock--
Quantity (Each) Price (US$)
1 - 2 148.00
3 - 9 142.00
10 or more 134.00
That's the source.
# Made in China
Item No: AL-470R-S
1 - 2 148.00
3 - 9 142.00
10 or more 134.00
yeah thats the one...very nice too....everything I ordered from them came promptly and correctly highly recommended🙂..I will have to copyright my handles and knobs though😎...oh yeah and drilling through 10mm aluminium for an IEC socket was not fun
DIY Tube amp and matching speakers
Just finished a modular rig for the living room. The dimensions and shapes were matched (using the golden ratio 🙂 ), so everything can be stacked and placed as needed. The name Aitoaudio is just a placeholder invented for the project.
Still missing but designed already:
Aluminum stands suitable for any module. Subwoofer: components ordered for a Rhytmik Audio Direct Servo subwoofer with a GR paper driver - crossing quite low as the speakers easily go down to 40-50 Hz.
Finished:
Speakers - Markaudio Alpair 10.2 in near aperiodic enclosures. Very nice full-range drivers. Speaker boxes are based on the ideas from Classic Golden Ratio Mar-Ken10.2 at planet10-hifi.com. More info can be found at the build log: http://www.diyaudio.com/forums/markaudio/191927-classicgr-mar-ken10-2-anyone-built-have-mods-what-do-you-think-about-them.html
Tube amp - a Chinese Sweet Peach EL-34B from an ebay auction for a decent price. After disassembly, used most of it for the amp module of the modular rig. Added a Bluetooth module and a charging iPhone/iPad dock. It already had MM and USB plus RCA aux in. The source is always Spotify high bit rate.
The white box is MDF and the top plate is 3 mm aluminum. The knobs are solid aluminum ones ordered from China. The most difficult part to source were rotary power switches (230 V) for Power on/off and BT on/off. Finally found some (made in UK) but had to cut and modify the plastic shafts to fit the 6 mm knobs - the shafts were too long and 6.3 mm in diameter.
Had to eventually replace a resistor as the original Chinese one was bad and causing sound degradation and even muting on the right channel.
Remaining: I checked the bias balance of the EL34-B's and they were quite close. Did not know the target value for this, so left it like that. But now I guess they are probably running too hot.
Power is not an issue, even now the stepped 😡 volume pot is difficult to use as step 1 is too silent and step 3 is already too loud for night usage. And there are 30 steps. Even at daytime it is impossible to use any volume above 1/4 of the scale.
Maybe it's a good idea to open up the amp again and rebias it - just have to find out the right values for EL34-B. Might as well replace a few other resistors at the same time, the originals looked a bit whimsy. And the volume pot. And some caps? And... 🙂
Mikko
That Ecotec version looks excellent!
The UK switch was all plastics, felt very uncomfy soldering it not to heat it too much.
I too would not use any other than rotary switches - preferably with heavy mechanical feel (CLICK, CLICK) and a solid metal knob with mass...
Mindutis: yes. Switches requiring brute tactile force make them feel solid. 🙂
Update about the bias: the Shuguangs were running at an OK level from the factory. The plate voltage was 401 V and the cathode currents were L: 52 mA and R: 53 mA - giving a a value of > 21 W which seemed high to me but the specs claim a max 30 W for Shuguangs - so it was exactly 70%. Tested a lower level and adjusted both to 40 mA giving a 412 V and thus 16.5 W. Seems enough for me (sound is the same) and maybe get a better life for the tubes?
Poddwatt
A recent build of Bruce Heran's Poddwatt......
6N1P drivers, EL84 (6P14P-EV) outputs.
Heath SA-2 OTs.
Power transformer was something I had on the shelf, but was a bit small, so I added a filament transformer.
Cherry knob and end plates.
RH84 from RCA Victor console
Console pull was a Canadian RCA Victor with a voltage doubler power supply. Initially I thought I would be able to use the old can caps, but the hum level was too high, so I stacked some new caps under the deck. I left the smaller cans in place, disconnected.
The chassis wasn't really suitable for leaving exposed, so I built a wooden case - open backed.
Box is finger-jointed black cherry with spalted arbutus sawn veneer faceplate.
The chassis is raised about 1/4 inch so that there is good air flow via the bottom gap and the numerous perforations in the chassis top.
RH84 from Chisholm console
Console pull - made in Port Moody,BC by Chisholm.
The IEC power entry fit (with some work) into the hole left by the octal socket which communicated with the tuner & control panel in the console.
I used the original tube sockets which were fairly good quality. Desoldering the (very well-done) original construction was a bit of work. Usually the final lug on the tube socket is the one that breaks. Either my technique is improving or I'm getting lucky: this time everything survived.😀
End plates are curly arbutus.
