Build your own 2x12" TH (The Kraken 212 TH)
you cant keep a real music lover down 😉
Tang Band W6-1139SI 6-1/2" Subwoofer
i picked the subs up REALLY cheap,
a little finish sanding/work and this will be the subwoofer for my new boom box build 😀
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=320-302
yes it sounds great,
not ive tested nothing.
the only math i did was *guess* that the cone area of a 6.5 is slightly less then half that of a 12.
so i divided all the numbers on the plans by 100 and multiplied that number by 42 (42%??)
my thinking is if the proportion of cone area to box physics is the same, i should get similar performance 😀
it definitely gets very low and is smooth in its delivery
thank you Petter Persson for the design 🙂
Sorry, i meant for your mini version of the horn
i arrived at my box calculations with some very basic math
seems i was wrong though because it seems a 6.5 is closer to 1/3 not 1/2 the cone area of a 12?
ive scaled many designs like this over the years, find a box design i like, find a driver/s i want to use, and built something i believe might work.
ive had good results so far, i never measure anything and always get lots of bass and never built anything i didnt enjoy using.
So, you didn't use the push/pull of the original design?
