To sir jojo:
here the plan i saw and planning to build. to be loaded with jh157 matched to Crell CA8..need your opinion...
Here is the link for this DIY...
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
if your planning to use this as your subwoofer for your SR...you might get disappointed...Crell CA8 will run out of juice and will just burn your drivers due to clippings...get an amp big enough for your Subs...
have a nice day,
jojo
have a nice day,
jojo
Thanks sir, it was enlightening...Sir due to budget constraints, i may not get a bigger amp than the CA8, how bout it will stay and just replace the speakers then. What would be the ideal replacement for the speaker? or the other way around.
just another info,
leach amp super amp pcb re design
http://www.diyaudio.com/forums/solid-state/51392-leach-super-amp-pcb-re-design-lsaprd-58.html
another leach pcb group bye,please watch out
a salute to pinoy leach master,sir tony
''salamat'' thanks for pinoy thinkers like you
hello audiomachines,one of my friends told me that you shared before a copy of schematic diagram of WESTRAK AMPLIFIER W/ PROTECTION CIRCUIT.kINDLY PLEASE GIVE ME A COPY SIR..Thank You Best regards.....
sir jo..
Can i use a Crown PRO-1540 PA for subs (200-400W)? to a CA8 Amp? is it overpowered? can u suggest a driver?
Im a newbie so better ask the pro...Thanks
Hello Sir! I am planning to buy 2 pcs 18" P audio speakers in Maniila, Can you please give me the contact number that you have in Raon Store? Salamat po in Advance!
sir jo..
Tibo for subwoofer application (28hz-50hz) it won't work well...maybe for Bass (50hz-250hz) it will do the job...I think C8 will do this job well at 4Ω per channel you just have to watchout for those clipping red lights...
But those 1540's are so weak...VC will not last...sorry man...you need to get a much better driver like the Crown JH159...
Thanks a lot sir...nway are M-Audio MA Series a good amps?
I have not use any of those... no commentThanks a lot sir...nway are M-Audio MA Series a good amps?
How bout sventa sir? or soundstandard?
I've used Sventa before but failed in a few months time. but power there is.
What went wrong sir?..
Hello,Kindly help me..i plan to buy P-audio SD18EL i do not know what amplifier can drive this kind of subwoofer which is very powerful according to ther other mobile owner..Please advice..Thank you.
the power supply just blown out. all caps explode. lucky still under warranty!
anyone can suggest me a nice looking and good sound dual 12" subwoofer box? for the back of my mini van
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
