Simplistic NJFET RIAA
Some pros use severall smaller caps in parallel so they can reach good tolerances during production.
As a DIYer I do not have access to expensive measuring equipment so I will welcome any tip about a better method for measuring acurately the resistor and caps values.
Tolerances for teflon RIAA caps
Hello chaps-
Still s-l-o-w-l-y working on my 2nd Salas jfet RIAA...!
Good timing on this tolerance talk. I sent an email requesting some teflon caps from Marko at 33audio. The link to his web store was posted here a few times. He got back to me with some matching results.
Marko's selection of 47 & 15 nF caps is getting thin. He was able to get a 'fairly' close set for me-
47nF "J" Tol, 200V, Custom TFHT 1.2 x .55----
.0471 uF, .0473 uF
15nF "F" Tol, 200V, TexCap 43 .87 x .32----
.01501 uF, .01503 uF
Apparently he has "a $200 hand-held DVM" and "some CRC 1/4-percent caps that I use for reference".
As he's been testing/selling for a while, I am assuming his results are somewhat accurate.
The 15nF's look OK, but the 47nF's might be a problem. At $15/cap, I'd rather get something lower in value to trim up. Anyone here cross-checked his results?
Cheers- Kent
Hey guys,
I measured my new cart without the body & without 4 Cardas screws that I must be removed because can fit correctly the cart with them so I used ultra small headshell leads, I calculate the moded cart weight:
-1.566gr body cart
-0.856gr 4 Cardas headshell leds
+0.282gr 4 new headshell leads
Total moded cart lost 2.14gr, now I understand that can get the same sound, 1st I believe was that RIAA needs a new adjust but isn't the RIAA the real reason it's the cart lost 2.14gr & that's decrease the effective mass of the combo tonearm+cart😡
Now I'm looking how to add these 2.14gr because the sounds is very very different, of course I prefer with 2.14gr more😉
Hello chaps-
.0471 uF, .0473 uF
Cheers- Kent
My caps where measured OK by Mark when I checked with my LCR.
Hi Merlin, last week I've disassemble my damaged ortofon MC-X5, I have found 2 pieces of lead in the housing, small one right at front (behind label), the bigger one near head shell, I guess you can add weight, but where and how many exactly? I don't know 🙂
I tried with a small piece of lead (2.14gr) fixed with blu-tac, see pic.
I added some mass to the headshell of the RB300 I am using with my DL103 and it works wonderfully.
I agree with you that the DL103 needs some mass to show it´s true character.
My friend Luis Pires (the man behind the Benz LP) kept telling me the benefits of using a high mass body for the MC carts. He personally chose the special African Wood used in the LP.
Maybe it would be a good idea to build a good wood body for the DL103..... 🙂
