500W PA amplifier with Limiter
Hi
can anyone share the apex VU meter ?
this one :
apex,
using tripple darlington,
with 12 output pair,
and 5200/1943 driver, what is the max supply?,
and how much resistance/ohms load can handle?,
how much power/watts?
Hello Sir ,
Thanks for the response.
Is it ok to use 50v rating for c2 and c5 ? I want to know the voltage drop across 100pf and 10nf when using +/- 70Vdc supply, have you tried to measure it Sir?
regards
yes for C2/C5.....
the voltage drop across the 100pf depends on the base-collector voltage of the trannie they connect to....no point in measuring the voltage drop accros them....
these capacitors are needed for frequency stability....you can use 600 or 630volt rated caps for these as they are available in manila...
Preamp Balance to Unbalance with Limiter and Bridge Mode
Hi apex, I try to incorporate some of the circuit that you share on this forum, I made the circuit as shown. My plan will create BALANCE TO UNBALANCE preamp with limiter and Bridge Mode.
My question:
1. whether the circuit that I made is correct?
2. for the Clip LED, whether componen value should be changed?
3. what is the function of the 10K resistors circled in the circuit Bridge.
usually for Bridge presence on Channel A. I listened to this series of Channel B is the Bridge mode.
4. I wear Voltage 15V CT.
Help me Mr. APEX is a series that I created is correct?
We are in the Corrections and given an explanation on what to do.
Regards.
i have a trafo from a dead amp...and still working fine...but i dont know how many amperes it was....until i read this ohm's law,im not pretty sure but my basic math says it was around 26amp...because on the back of amp housing it was indicated that 5000w max input......the output is 96v-0-96v....96+96 x 26amp6= 4992......did my figure is correct.....pls correct me...if i didnt get right computation...thanx a lot
Thats normal, its called a turn on/off thump and is caused by rc time constants at the ltp inputs due to the input and feedback cap beeing a different size and thus take different time to charge up.
Why you don't hear it in commercial amps is because of the delay in the speaker dc protect circuit on turn on.
I built this speaker dc protect circuit and its working nicely:
thanks tekko for the reply.
but in nmos amps i didnt hear that sounds. why is that?
do u have the pcb of the dc protect ciurcuit.
