4P1L DHT Line Stage
Hi all,
I´ve been following the 26 DHT pre-amp thread with a lot of interest for some time. Hence, I ended up playing with LTSpice on a 4P1L line stage circuit as this valve is more than attractive due to its superb linearity. I´m sure that there are multiple and varied opinions around which DHT valve is best for a pre-amp, but the 4P1L seems a great candidate bearing in mind its cost.
As I don´t have any choke or transformer at hand, I´m looking at a DN2540 cascoded CCS as anode load. Target quiescent operating point is Ia=10mA and Va=150V/Vg=-10V. Not sure if this point is the best for this valve, I will try its sound unless anyone has any suggestions...
I was looking at fixed bias, but as there are multiple opinions around which bias setup is best, I just simulated cathode bias with 1K resistor (see diagram).
I guess that I could use Rod´s DHT filament board or a simple LM317 as a current regulator?
This line stage is intended for my 45 SET amplifier which has 47K as input impedance. Hence the 47K load resistor.
The stage gain si around 7.7 as expected. I have 220nf teflon capacitors so frequency response will be limited to this, which is not bad at all.
Based on the 26 pre-amp thread, many have tried LED bias, cathode resistors, filament bias and fixed bias with batteries. What will you recommend for this setup?
I´m throwing this out as an idea, so hopefully haven´t made too many mistakes .-)
Ale
Ale, It's well worth trying this DHP in a line-stage, and I think your basic architecture is a fine starting point.
The power-supply rejection will not be so good, and consideration for a shut-regulator, eg.: SSHV will be good value-for-sound, I suspect.
Noise rejection in general will be the difference between good and GREAT sound. Building with the mains transformers in a separate enclosure is surely needed.
Multi-turn ferrite beads in the grid may be worth trying, and a Farnell 1635783 bead in the power feed (both sides) may help keep MW/HF radio out of the circuit.
Noise voltage on the filament supply will be amplified in a grounded-grid style - same gain as at the grid! Noise currents are added directly to the anode current - since they share the same internal conductor and terminals. With a LM317, you can measure the noise (voltage) with a scope, and compare with a line-level grid signal.
The whole circuit is best wired compactly, using wires no longer than strictly necessary. This minimises the EMI loop area - the "grip" that electromagnetic noise can get on your circuit.
Curious here... What makes you say that the PSRR won't be good?
Noise floor will need to be reasonably low, yes.
I question that, honestly. The leakage field from even a cheapie toroid - like the ones from Antek - is minuscule. For an EI core this is different. I actually measured the output of an amplifier versus orientation of the (toroidal) transformer. I wasn't able to change any of the 60 Hz harmonics' amplitude by moving the transformer or rotating it. Granted, this was in a smaller circuit (SMD components, small inductive loop areas), but still... I was quite surprised by this result. I had expected the transformer orientation or proximity to have some impact. I was planning to use an external supply for the amp, but could place the toroid right up against the amp board without seeing any increase in 60 Hz (or harmonics) on the spectrum analyzer. Instruments like spectrum analyzers (HP 3562A, quality sound cards, etc) or wave analyzers (HP 3581A) are your friends for these tasks.
Separating the amplifier from the power supply opens up a giant can of worms (or whoop-a$$ if you're not careful). You have to really plan out the grounding scheme (both from an electrostatic shielding perspective and a safety perspective). Then add that you'll have 250 V DC running through a fair amount of cable. Of course, like any other engineering challenge, this can be solved at some expense (both money and time). I would build the amp on a prototype setup in the lab first. Get it to work on an old sheet of FR-4 first. See if a separate supply really is needed. Then decide if that's the route you want to take. It's one of those things that look great on paper, but can come back and bite you if you're not careful.
As you can with any other regulator. A multimeter with relatively wide bandwidth (HP 34401A or the older 3478A for example) are real handy for this. Scopes work too.
Absolutely agree. For inductive coupling, reduce the loop area. Inductance is proportional to the loop area. More inductance --> more coupling. Signal return currents should be in close proximity to signal forward current.
~Tom
Tom, please read the thread "26 Preamp" to see how this is done correctly.
You are right inasmuch as the Toroidal trafo does not radiate magnetic stray fields, but this trafo style is only a good choice for linestage duty when you have no HF/RF conducted noise on the mains supply. Not many locations can apply! This is due to the toroidal's winding style, with all the secondary windings scatter-wound directly on top of the primary. High capacitance in other words, ideal for coupling all that HF straight into your circuit. Sure you can try to filter it, but I believe that most designers would rather just eliminate the coupling and not have the noise.
In addition, the core material of a cheapo Toroidal is usually unconnectable, and floating, it can do nothing to help suppress common-mode HF mains noise being radiated from the windings, and coupled into the signal wiring, signal interconnects, etc. And since mains feeds are long tightly-coupled cables, the majority of the noise will be common-mode.
Split bobbin EI trafos, with grounded core, offer hugely better insertion loss to high frequencies, and the connecting the core to chassis is very effective in smothering emissions. That's the budget choice. For higher cost, properly constructed EIs with interwinding screens improve the noise rejection further.
The 26 line-stage builders will vouch for the lack of difficulty in making 2-enclosure amps work. The chief concern is to keep the trafo/rectifier/choke/first cap closely coupled (in the mains enclosure) - which puts an end to any recharge-pulses in the ground wiring. After that, one ground wire to the signal stages, and a cap to decouple the B+ wiring. With CCS loading, the valve stage do not impose current pulses on the supply - so sharing between the two channels is fine. And even if it was not fine, using 2 shunt regulators would completely suppress that problem.
I am not suggesting we run 10-metre cables between the mains enclosure and the valve box. 300mm will suffice, a little more will be plenty. If you have safety concerns, just use steel-wire armour cable (= outdoor duty mains cable). In the UK this is rated safe to carry our 240V mains across the outside of walls, no further protection required. It's used in large quantities, and available cheap.
No doubt meters exist to evaluate the noise on my CCS/Gyrator based filament supplies, but no instrument in my possession registers anything at all. The TEK 465 shows ZERO perturbation on any scale, and the DSOs don't match the resolution of the 465.
This is no surprise, since the regulator does not contain any references, zeners, bandgaps or anything else, and the noise can be narrowed down to the contributions of a couple of transistors and a sub 1-ohm resistor: down in the nV/(Hz^0.5) in other words. The transistors are run at high current, and have low Rbb, too - so the figure is low even for the circuit structure.
Rod,
I still didn't get an answer to my first question about PSRR.
- Line filters would be one way of combating that as well. No filter is perfect...
- Another way would be an electrostatic shield. Antek has started to offer shields on many of the their toroidal transformers. No shielding is perfect...
- EI core transformers would suffer from the same issues regarding HF/RF coupling through the transformer. Of course, a split bobbin type will reduce the coupling dramatically as well, but many transformers are not split bobbin.
But fundamentally we agree. The toroid wins on leakage fields, but loses on RF coupling between windings. A split-bobbin (note that this is often a value-add option) EI core wins on the RF coupling, but loses on the emitted leakage field.
Whether the RF injected via the mains power supply impacts the sound quality at AF is another story. It's obviously desirable to not have the EMI in the first place, but few people live in a screen room. Those of us who frequent screen rooms often don't even bother to close the door... 🙂 As you also point out in your first post, RF induced on signal cables can be an issue as well. I tend to put EMI filters right where the signal cable enters the amp.
I agree. It's always better to eliminate the source of the issue than to attenuate it. However, a split-bobbin transformer will not eliminate the coupling. Only reduce it. Unfortunately, physics dictate that if two conductors are in proximity on one another, there is a mutual inductance between them (as well as a capacitance). Just one of them annoying physics things.
Trying to learn something here... Would you elaborate on how grounding the core helps on reducing the radiated field?
Agreed.
Do they have measured data? I guess I should plough through that thread. Sounds like an interesting one... I've only read bits and pieces.
I don't see how shunt regulators would suppress the problem of current pulses any better than a voltage regulator would for exactly the reason you mention in the quote above. Neither regulator has infinite line rejection.
Cable and connectors is one thing. Making sure the safety/chassis ground is run properly is another. If one understands the problems involved, sits down and draws it out, it's a manageable task. But it only takes one ground loop (easy to do) to screw it up.
Nice!
Well... There has to be a reference somewhere. Even if it's a Vbe or a Vgs. But I get your point. Would you point to the most recent schematic? I'm getting curious now.
Thanks,
~Tom
It's a nice-looking tube. I've been mulling over building a low-power DHT headphone amp with those. Incredibly linear and good pricing. What's not to like... ? 🙂
You may not need the cascode. The semiconductor CCS'es have quite high output impedance as-is and don't suffer that much from channel length modulation (MOS analog of early effect). Of course, the cascode, generally, improve the CCS'es but there may not be much difference without it.
Those are options. Constant voltage is another option. I have never been able to measure or hear any difference between constant voltage and constant current, so I go with constant voltage for cost and complexity reasons. I actually use switching regulators for this on my 300B amp. You can see schematics and measured data here: http://www.diyaudio.com/forums/tubes-valves/175695-300b-switchmode-filament-supply.html with a follow-up in post #17. You'd, obviously, have to tweak the feedback resistors to get 4.2 V rather than the 5.0 V I use for the 300B.
With 1 Mohm, 220 nF should yield 0.7 Hz lower cut-off frequency. Whether 1 Mohm is enough to prevent the grid leakage of the tube from causing issues is another story. I don't have any experience with the tube, so I can't really tell. But 1 Hz is plenty low.
I like LED bias. The dynamic impedance of a RED LED (HLMP-4700 for example) is on the order of 10~20 ohm so it behaves reasonably close to a 1.7 V battery (at 10 mA forward current that is). That tends to result in very low distortion (I'm measuring below 0.01 % THD+N on a 6J5 (one half of a 6SN7) running at 1 Vrms). A simple LED beats the other types of biasing schemes on performance and/or complexity 99.9 % of the time.
One thing, though... The power supply (B+) needs to be really clean. I recommend using a voltage regulator. You can also use heavy RLC filtering or other regulator types.
~Tom
Tom, we can put some numbers on the difference in HF insertion loss.
For some trafos loafing around on my bench, the capacitance measurements were:
split bobbin:
- 240V pri;
- 370V sec; 150VA: split bobbin. C(pri-sec): 70pF. C(pri-core): 85pF
Toroidal:
- 12V 150VA C(pri-sec): 300pF
- 54V 100VA C(pri-sec): 720pF
We might expect from this that the interwinding capacitance of a Toroidal B+ trafo might be 1.5nF or more. If that's anywhere near correct [don't see why not] - we will get 20x better insertion loss using the split bobbin EI.
The split-bobbin type I measured was an industrial type available new at a very low price:
150 VA
Builders in the UK need not hesitate with these - you can specify winding voltages for secondary AND primary as any voltage you like. The quality and service from this company is first rate.
As for connexion to the core: Consider the toroidal trafo usually has [for safety] the primary wound next to the core. Judging from the interwinding capacitances, we will get > 1nF of capacitance to use as a filter, which would reduce the noise out to much higher frequencies than ordinary capacitors can. But not if the core can't be connected to chassis.
Personally, I regard split-bobbin trafos as a minimum standard for DIY audio. Not to mention that the JMS types are lower cost than any other solution! Here in the UK, anyway.
Mileage may vary in different locations, and not everyone likes the look of industrial trafos, but then if you have more spend available, there are many high quality options, including screened secondaries, ornamental end bells, even fancy core materials.
I am thinking of a building a linestage, especially one using the 4p1l as I have almost completed gathering all the parts for my all loktal power amp. Its in prototype stage at the moment but it is giving a nice 100W RMS straying slightly into AB2.
Anyway to confirm some comments by you guys. I initially used a crappy mains torroid for phase splitting duty (actually listening to again now). I stuck it on top of the Antec mains toroid and can confirm the radiated field is minimal. With an old relay coil accross the scope probe as a search coil it shows a very small amount of radiated field compared to an EI.
One problem though. any mains born noise comes straight through. I put a filter in line and this has cured a fair bit(I cant hear it but its there) The trouble these days is that more and more domestic appliances use switch mode supplys. Also another really nasty one is fridges they use a capacitor run type induction motor that causes alsorts of hash on the mains when they start up at random.
Another problem with toroids is the fact that as they have such a good core, they are wound so they are near their limit for saturation(penny pinching scroungers). Any DC offset on the mains will screw them bad and you can hear the buggers hummmmm then. If you live near an industrial site that uses a lot of straight off line inverters for motors you will know what I mean. I have a variable 10-20VDC bias on my supply. The place I lived before had the 11KV sub at the bottom of the garden and I had the luxury of a very clean supply. Not so now.
So, Rod, how did you get on with JMS? Are they any good?
I will be reading this thread with interest.
Cheers Matt.
Dang. Nearly 1 nF (possibly more for higher voltages) between primary and secondary. I wonder what it reduces to with a shield between primary and secondary (shield grounded). I'll drag my Antek tranny with me to work one of these days and measure it.
Looks like a pretty good deal. Nuttin' wrong with that!
Yep. And the capacitances you measured also indicated that the cap from primary to the core was higher than that from primary to secondary, so if you ground the core, less than half the signal should couple to the secondary.
I hope you're willing to share the schematic for your DHT heater regulator (or at least link to it). I saw some of the earlier revisions (I assume) in the DHT heating thread. But something tells me you have the thread and post number memorized... (Or maybe that's just a projection 🙂).
~Tom
Tom, Rod,
Thanks for your invaluable contribution to this post! I can't believe the exchange of ideas and suggestions between the two of you 🙂. I have a lot to read, though.
I was looking at separate chassis as well.
It seems that the key point here is to design the cleanest HT and filament supplies as possible. Given the options thrown so far, I'm still confused as to whether a Salas Shunt HT supply or Tom's supply is the way forward? I'm keen to go for a simple design with components easy to get hold of (at least in the UK).
Rod, what about your filament regulator, do you have one suitable for this filament voltage/current?
Tom, thanks for your tips as well. I will try LED bias then...
Ale
Cheers Matt.
Here's a wide-open split-bobbin shot of the JMS 150VA. [Let's see what the smut filter makes of that 😀]
Secondary is 340V and 30V. 70pF C-winding as above.
Pros of JMS:
- Proper tough industrial quality split bobbin.
- Insulation standard, terminals and earth stud are rugged enough to satisfy a Victorian.
- Lowest cost I know of.
- Order on the web, specify the windings any voltage you like.
- email to Sean and he'll tell you what can be done, including accurate predictions of Rdc [if you are into critical damping, or just want to model it accurately before specifying the turns].
Cons of JMS:
- Only do courier shipping [£10], so it's best to buy a stash for a few projects.
- Varnish finish is strikingly similar colour to the sauce around Heinz baked beans.
- 150VA is the smallest type that is definitely split-bobbin. ask Sean if you need something smaller, and check.
- No end covers for chassis-top showing off. Steampunks beware - These are best exiled to the hinterlands of the chassis set.
I have used them 3 or 4 times and rate the service highly - only a few days to deliver, even on full custom windings. I haven't used 6V heater secondaries, since I have a stash of heater/filament trafos, and don't like overwinding heater/filament supplies anyway, due to risk of coupling recharge pulses. Ask Sean if you need these, and see.
Tom, here's the schematic for the regulator and the raw dc supply.
The production version is refined a little, to improve LF ripple rejection and render it adjustable. I don't want to post the as-manufactured schematic while they are still available, as there have already been a couple of clones seen out there [which are unsupported, BTW!]
The operation is unchanged though -
the top portion is a passive gyrator:
- reduces incoming ripple;
- provides high insertion loss (HF transmission path is <100pF only)
- bottom section is a Vbe-referred current limiter, using NPNs with low-noise capability, and low Cob. Again the insertion loss is good up to very high frequency, and permits operation of DHT amplifiers even in systems with noisy CD players nearby. [Try waving a scope probe in front of a CDP display, to see why this is important!]
Overall, the filament is treated to wideband isolation from outside noise, and includes no significant noise sources of its own.
I originally wanted to make the manufactured units with a voltage-servo, so that the regulator was a dc-servoed CCS. I tried adding an opamp voltage loop, with <1Hz LF rolloff - but this destroyed the 3D imaging and subtle resolution of orchestral music. Out with it!
There has been lots of good feedback for the outcome:
http://www.diyaudio.com/forums/tubes-valves/38248-new-dht-heater-5.html#post2336382
Tom has prepared some PCBs, and the parts should be easy to buy and fit - so you could do the comparison!
I don't know if the SSHV has been laid out by anyone yet, so some hacking would probably be needed.
In either case, the proper test of an audio regulator is by comparing the sound to LC or preferably LCLC unregulated supply.
Even when a regulator is used, an LC filter is a good idea, since the 1st-cap recharge pulses are lower in peak, and much smaller in bandwidth. These large peaks can find their way back into your circuit by EM coupling, even if a filter is used.
[/QUOTE]
Ale
All models of the regulator are still available! please send me some PM. Maybe you have my email address from the 45 filament reg buy, or click on my name to send some email.
The standard 4P1L model can adjust from 260mA to 380mA [4P1L spec is 300 to 350mA]. It runs best from 8.5V to 12V of raw dc, so a 9Vrms 30VA split-bobbin trafo works best.
Use one trafo for each 4P1L for best results.
Awesome. Thank you.
Clones... Damn. I don't mind if people build my circuits for themselves from the schematics published - that's part of DIY, but cloning the design for money is a completely different story. In a way that's sign of success, though.... 🙂 But it is one reason I would never give out Gerber files (and I'm sure you don't either).
I'm highly skeptical of that, but we've had that discussion before... I'll just have to try it out for myself. If I can tell a difference, count on orders from me.
Thanks,
~Tom
I have a 4p1l preamp playing in my system using Rod's filament supply boards. Power supply and filament supply are both in separate boxes and both use heavy, multistage crc filtering (HT supply also includes a choke). The preamp is even quieter than my //6cg7 one was and the overall sound is better too. Clarity is very good, but this is not a "plug it in and enjoy" type of tube.
Firstly, the sound tends towards the thin side. You need to be able to fiddle to get it sounding balanced. Even biased at 26mA, it still sounded thin, though also slightly aggressive. That having been said, they are driving a very unkind load - 1 solid state and 1 hybrid amp - but my previous pre was doing the same duty.
Secondly, microphonics are a something you have to be able to deal with or live with. Every touch on the volume control or box is greeted with an answering "ping" or "ting" - heck it even rings when my dog barks! Admittedly, I have them upside down at the moment and perhaps they will be better when I can turn them over, but it will be a while til that can happen.
HT supply at input is 233v and anode resistor is 4K. Anode voltage is 125v. I started out using 9v batteries for bias, but have since added a single red LED in the cathode circuit, bypassed with 330uF Oscon. I have a whole mess of input capacitors in place to "tune" the sound. It is very, very listenable at the moment and I wouldn't want to go back to my 6cg7's, but it is still a work in progress. I may try fiddling some more with caps and am considering adding a cathode follower to give it a kinder load, though I am dubious about adding more components into the signal path. If I can direct couple, then at least I won't have to add another capacitor in line.
In triode connection the rp is pretty low, (a few K) your 4P1L should be able to drive rather low impedances without much trouble. I'd run it at a higher plate voltage, and current. I think Anatoliy likes something around 200V, and I would say 30mA or more.. Choke loading or CCS would be icing on the cake...
You would need a very high current CF realized with a high transconductance triode or pentode to significantly better the performance of the 4P1L into low impedance loads.
One could also add a cathode follower or source follower... In the latter case, the output impedance would be measured in mOhm... Or at the worst a few ohms. In case of the cathode follower, it'd be about 1/gm or 150-ish ohm.
~Tom
Thanks for the replies guys.The preamp is actually doing a fairly good job as is, but I don't think I am alone on this forum in always wanting to find some way to improve things.
I don't know what the input impedences of the 2 solid state amps are. Both are without volume pots. One is a moscode (trioded EL34 / bjt cascode driving mosfet source followers). I have the original article about this design, but there is no concrete info on the input impedence to be found in it, except the following, (which I don't really understand):- "The shunt feedback reduces the input impedance seen at the base of Q1. As far as signals are concerned, it is virtually at earth potential, which is why it is called a virtual earth amplifier." It doesn't sound to me like an easy load for a tube of any sort to drive, particularly with no volume pot, but I am not very clear about this and could be wrong.
The other amp is a Hart Linsley Hood kit amp with passive RC low-pass filter at input. I can't imagine the combined impedences of these amps could be much, and the capacitance of the passive filter is probably also a bit of a bitch to drive, though no HF is required from this amp, as it drives my woofers.
Kevin, thanks for your input. I always value your suggestions. I am not about to throw money at this preamp. I am fiddling with it while I wait for my Edcor OPTs to arrive so I can get going with my //SE 4p1l power amp. I can raise B+ voltage a bit by reducing the values of the R's in my crc filtering, but the trafo has only a 200v secondary, so I will not be able to get the plate voltage up to that kind of level, especially at such high mA, without a new trafo, or resorting to solid state assistance (or significantly dropping the plate load). Choke loading would probably be good, but is not an option at this point. I tried loading preamp tubes with gyrators in the past, but was not overly enamoured of the sound, which I found a bit on the analytical side. Even worse was the very noticeable hiss - so I would be reluctant to go down that road with the inherently bright sonic signature of this tube (and the high dissipation of SS devices required at this kind of idling current.) I do not need more gain either, and could in fact live comfortably with less. Maybe some local feedback? What would you be inclined to do if you were in my shoes?
My thoughts are revolving around possibly using 6n6p's as White cathode follower or CF with active load (a la M.Jones) or possibly Mr. J.Broskie's Aikido CF. Other triodes I have in stock are 6CG7 and 5687. Pentodes include EL34's, 6CA7's and 6j4p's. Thoughts?
