not much really, you just use thick open cell foam.
I'll try to get a pic.
I thought the bastini had a similar thing on some.
Norman
Norman
Bastanis Prometheus review on 6moons.com
here is a link, look 1/2 way down the page.
6moons audio reviews: Bastanis Prometheus Mk.II
Norman
Norman
Foam box around back side of the driver.
is the foam soft or hard like styrofoam?
Tang Band w8-1808
The open baffle is 5' tall made of 1/2" baltic 8 ply birch (2 hinges).
The panels are 12" wide center, 15" wide left, and 19" wide right.
Driver center is 37" off the floor (middle of tv).
I also run a 12" woofer with an 80hz f-mod (rolls 6db/octave).
Without the woofer module, I consider it unlistenable (rolls at 200hz).
Norman
I spy an Altec 9440a. Awesome amp, wish I had kept mine. 😎
soft foam. Maybe a few towels can be made for something similar.
Yup, love my 9440a (eventhough it only works on 1 chanel and I'm losing an input ground). As the input control is turned up, the more buzz. Playing a cd is fine, but needing more gain to play a movies is too buzzy.
Norman
Norman
Looks like a rather nice Coral alnico tweeter (or mid-tweeter) in the bottom left corner.
dave
dave
another chance on ebay:
ALTEC LANSING 9440A VINTAGE POWER AMP AMPLIFIER 400W X2 | eBay
I have one of those. Used it to drive four 421-8H-SII
15" woofers, one in each of four 816A cabs for about 300 Hz down. Works good.
This amp uses a DC voltage regulator circuit for the meter illumination lamps so that they won't brightness modulate to the music with the power bouncing and dipping on the mains circuit due to significant peak power draw from this powerful amp.
please note the link in the auction to the user's guide that includes a schematic in the event an owner needs one.
Vintage, i was expecting tubes...
dave
wow, yea $850 is a bit steep. someday I'll get mine fixed.
Lol, is early 80's vintage ?
Norman
Norman
Norman
Speaking about Bastanis speakers on their website they actually have plans you can download for free so the DIYers are able to build the same exact 15" or 18" woofer non symmetrical w-frame dipole sub design they use in their Bastanis Mandala! You can download a 22 page PDF file of the plans for those subs here: http://www.bastanis.com/pdf/Mandala_cutting_plan.pdf The plans are quite complete and tell you pretty much exactly how to build their Mandala's w-frame dipole sub. You'll just have to decide which drivers you want to choose to use in your DIY version. What more can you ask?
Thetubeguy1954 (Tom Scata)
you might want to download that manual and save it. probably won't be too difficult to repair, if you know how.
the altec amp sold for the BIN price.
this chap has a bunch of "goodies" for anyone in the middle of the US.
aaokc | eBay
aaokc | eBay
Zenith Boomcase
Technically full range...
Vintage Zenith service technician case with...
2x GRS 8FR-8
41hz Amp32-PS
~1.4Ah 12V SLA Battery
Alps RK097 pot w/ internal power switch
Sounds pretty good, little heavy on the bass and light on the upper treble, but exactly what I expected out of a 8" paper whizzer cone speaker. I just tweak the EQ a bit and am very happy with the results. Usually fed off a Sandisk Clip+ running RockBox, sometimes a fully rooted Nook Color w/ PowerAmp or streaming Pandora for a bit of variety.
2x GRS 8FR-8
41hz Amp32-PS
2x GRS 8FR-8
41hz Amp32-PS
Hello Velmeran!
Those two GRS 8FR-8 drivers ---{did you check to see who their actual manufacturer is}--- would probably sound a whole heck of a lot better, and not so bass heavy or light on the upper treble extreme "if" you removed them from that box and placed them in cabinets that are better suited to their specific requirements!
Granted they probably wouldn't remain quite as easy to move around, but they'd sure sound better that way! Of course that's just one man's opinion and if you're very happy with the results you're obtaining from just tweaking the EQ a bit. Then you should just keep continuing doing, what you're doing!
- Full Range
- Full Range Speaker Photo Gallery
