I will try adjusting the offset and see how that affects the voltage across R7.
Also I only have one pair of mosfets per channel. Bias is at 2A per channel. And the sound does get better as you bump the bias up.
And I will study the schematic.
Thanks again
Scott
Thanks again
Scott
Also did you select a LED to increase the source to drain voltage to operate in a more linear region?
to leave more voltage for CCS, to breath .......
voltage level at source side of JFets is always the same ; Jfet doesn't know and doesn't care is +U 10 or 10000V
