From the description, it is not an F4, but a modified BA-1. What's with
the resistor to the V- after the output cap?
your reply pretty much sums up the reason I think 1000 times before posting pics. wanna know my opinion? I'm sick of those luxuriously looking clones of commercial products with readily built, very expensive cases. that has nothing to do with DIY. if one uses good parts, has soldering skills and doesn't skip anything important there's no reason for things to go wrong. and amp is a good amp no matter the look of the case. and TBH judging by the look of the solderings it is pretty well build, I've seen much worse.
as for bias, I didn't yet, will do so soon and post results.
That's why I said "to me...."
I don't understand why you've started this thread. To **** off people in the Pass Labs forum? Clearly you don't intend to spend time to understand if anything is wrong with the amp. You didn't even build it yourself... and then you compare it to a commercial class D amp.
While I personally don't enjoy the sound of Class D, I'm willing to believe that they can sound good if done right. However, I'm not willing to believe that the F4 sounds "bad" in comparison. It may not sound as good to you, but it certainly doesn't sound bad.
Nelson, to be hones I wondered about that too. is it OK if I dropped it and omitted only Q204 and the parts around the Zener from the original schematic? http://www.diyaudio.com/forums/atta...4350155-f4-power-amplifier-pass-ba1-front.jpg
continuing a conversation with you is clearly wasting my time. you seem to be excessively biased, while most of the people realized that this is not meant to **** anyone. if I'm not posting pics or measurements the very next second someone is asking me to might maybe mean that I have more important things to do at the moment?That's why I said "to me...."
I think the outputstage is an F4, there seem to be SK170 and J74 on the right side and the source resistors seem to have 0,47 Ohm.
you dropped the correct parts for biasing, it is done by the F4 components....TL431
and the output semiconductors are marked with different colours so they could be complementary.. but mr push pull can look!
at the input of the outputstage is 47k and 1k at the j-fet input (last picture)
or are my eyes bad...?
Clearly. What irks me is that you start a thread by saying that the F4 is beaten "hands down" by a commercial class D amp without so much as admitting that there may be something wrong with the F4 clone (a poor one at that). I'm not asking for any measurements, but only your admission that there may be something wrong with it.
I cant' see how you're still failing to see that I clearly admitted that there is clearly something wrong with the build (which is not a clone by any means IMO).but only your admission that there may be something wrong with it.
If it's an F4 OS, then you don't need any of the parts around the zener or
Q204 for that matter.
Mr P-P,
hope you don't mind me saying, but the heatsinks of the amp seem to be assembled with scrap parts.
The L-angles that hold the output devices appear to be attached to the heatsink contraption by a single bolt in the center.
With such a slip-up, there's likely a range of issues with the build.
DIY isn't about expensive cases, more to do with attention to detail.
(checking JFETs for authenticity is very easy, the little ones in particular)
I wrote about the "heatsink" issue myself, but after 3 hours of service the temp of the transistors reaches about 65 deg Celsius. they're attaced using 3 bolts each.Mr P-P,
how do you tell fake J109's? that would really help.
and now that I looked closer at it, it looks like there are visible gaps between the L profiles and the plate they're attached to, something to consider fixing. I had imagined that the one who built it ensured they were flat...
To me, that looks like a shoddy job. You could do well to test all the connections, etc. Like you say, if it sounds plain bad, there must be something wrong with it.
Your such a sensitive guy😀
OK I left the amp on until the temp near the output transistors reached 50 deg C as manual says.
voltages across the 0.47 ohm resistors are:
Q3..Q8:
0.202, 0.207, 0.202, 0.218, 0.203, 0.192
0.207, 0.212, 0.214, 0.213, 0.213, 0.199V
DC offset at output is 22 and 18 mV.
Q3..Q8:
Have you tried the phase test yet ??
The DIY Pass and the Class D should be pretty close in terms of performance if they are both working correctly.
A radical difference indicates a problem.
did it few minutes ago. the phase is correct.
so it narrows down to the BA1 front end. I'm currently reading on here about fake J109's.
Q3..Q8:
o.k. these values seem good enough to me.....🙂🙂🙂
did you adjust the frontend?
and when all is done we have only one problem.... how can we make your class D amp sound worse .....
but I do not know anything about class D to make a suggestion....😕
my two last orders of J109 were indeed fakes, uneven and high Idss values.....
well - without gong too much in possible issues ( except already mentioned that every discrete OP , which used BA FE is , needs elaborate PSU reg ) I can say just one thing - my F4 specimen , known as Papa's Koan , is blameless as much one power amp can be blameless ;
if paired with proper speakers - it will sound exactly as gain stage in front of it .
accent is on "if paired with proper speakers" .
no-one can expect miracles from 25W/8R amp .
name of the game is FW , not 75-th W
so - we are speaking apples and oranges here - 78 posts and counting ........
- PASS DIY F4 beaten hands down by my class D amp, what's wrong?
