I got a carpenter to build a very nice box, painted with black polyester, and added a couple of minispikes (I painted them bright yellow, with clearcoat).
I put them on my office desk. This is not a joke - everyone stopped by and commented about how good the speakers sounded. A friend, whose father is a dedicated audiophile, stopped by and said "those are some of the best mids and highs I've ever heard!". And then he looked for a hidden tweeter - or woofer.😱
All this, while listening to the speakers powered by a T-Amp being fed by a regulated 13.8V power source.
Thank you so very much for this excellent design. I'm enjoying them more and more as time goes by. It's the best way I can think of starting in DIY speaker building!
It's a very nice little amp, but I must say the HiVis deserve something, if not better, quite a bit bigger. I plugged them to my hybrid integrated (75W vs. the T-Amp's ~6W @ 8 Ohms), and the difference was very easy to spot. I wish the HiVi driver had a higher sensitivity... around 10 dB's higher. 🙁 It'd be the perfect full-range speaker for low powered tube amps. As it is, the midrange is positively gorgeous... IMHO, better than a pair of Omega's I had (the ones with the banana pulp cone).
How will these serve as studio monitors that translate well to consumer audio?
Well, I have a thread I've opened , Zaph can you please read and advice?
http://fullrangedriver.com/forum/viewtopic.php?id=1800
Adam
Adam
Bringing back a really old thread. On Zaph's site he says:
"This speaker requires a subwoofer and a proper subwoofer crossover. Like all other 3" drivers, this speaker has serious harmonic distortion below 100hz. When running this system full range, the bass will sound thick, muddy and too heavy. It's not the driver's high Qts doing this, nor is it the choice of baffle step compensation. It's the 2nd and 3rd order harmonic distortion. When you play an 80hz tone through these, you also get a loud dose of 160hz and 240hz. Don't make the mistake of thinking more bass is better bass, particularly when "more" comes in the form harmonic distortion. This design has terrible bass distortion and should not be run full range. Period. You owe it to yourself to learn the sound of distorted bass. Run these full range, then take a listen with a good sub and a proper sub crossover. The difference will blow your mind, and then you'll understand what good bass really is. More on a "proper" sub crossover below."
If I plan on making a pair of these to mount outside on a small boat I work on, and I don't intend on using a subwoofer, will they still sound good? Should I still use his crossover? I wouldn't be able to hear lows over the 300hp diesel engine rumble anyways.
If they sound decent, I will be extremely happy!
Perhaps just filter out some of the lows from them then. Might be as simple as changing the amplifier input coupling capacitor to something smaller to give a -3dB point (6dB/Octave slope) around 100Hz. As you say, the lows will be lost anyhow and by filtering them off you'll get more dynamic potential.
The HiVi B3N/S has a fair upward tilt, so if you filter out the VLF (as per Dr. EM) and don't expect any bass, they might cut through OK. Be warned though, they are quite inefficient and may need a few ergs (aka 50WRMS or more) to get up and over your extreme noise floor....
True, thermal handling could become an issue. If you don't need much bass but do need good volume up higher there may be better (more efficient) choices. Monacor SPH-30X and Fostex FE83 spring to mind.
Well I purchased a few pairs and I'm going to give it a shot. I'll do a quick experiment in some left over 4" pvc pipe I have on one pair, and if I like what I hear, then ill make the rest or return the others. I'll need to figure out how to change the amplifier input coupling capacitor to get to the 100hz.
Space for mounting the speakers is the biggest issue on the boat, then price for the speakers. That's why these little guys interest me so much.
Thanks for the input!
Hey, that's great. Post some pics.
Did you add the baffle step correction filter to it?
I'd think they'd make awesome PC speakers.
What did you use as a regulated PS for your T-amp?
If you aren't using a sub...
Dragon Foal pictures by wolf_teeth_speaker - Photobucket
^^^I'd build my Dragon Foals over the Zaph B3S. M3N driver instead.
I have a blog over at PETT that the writeup is posted within for more information, and I posted a pro/con comparison.
Later,
Wolf
Later,
Wolf
Great, they look awesome. I read the hi-vi spec sheet for the B3S and it recommends a sealed 2L box. Which is great for me, I'll be using them to replace some computer desktop speakers.
What software did you use to simulate your speaker enclosure & crossover?
If you mean me- Unibox, and RM/PCD.
Later,
Wolf
I found the unibox spreadsheet, where do I find RM/PCD?
Thanks.
jbagby
These will only work in MS Excel. Open Office, Office for Mac or some emulators do not allow the use of the VBA code routines to work in those spreadsheets.
Hope that helps! If you have Q's, search at PE-TT for some answers, and Jeff posts there.
Tech Talk Forum - Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com
Later,
Wolf
Well my first prototype was a huge success. I got more than I could of hoped for in quality and loudness for these little 3" drivers.
The most expensive part are the black abs end caps at 6.50 each. Each speaker needs 2
Hey, aren't cylinders supposed to have really bad diffraction effects?
Read my mind, as well as being not what the design called for.
Later,
Wolf
- I just built Zaph's HiVi B3s speakers... thanks a lot, Zaph! :)
