In the mail-bag from Audio Precision -- you might find this blog-article (it's a tease by the editors of EDN) interesting. And some of the respondents include RAP!:
Audio Precision to the rescue, of Jim Williams no less - Anablog | Blog on EDN
Hello jackinnj,
Yeah, it seem to be a new great work from Jim Williams !
Now, i'm pretty impatient to read the next EDN issue.
And maybe we could build it to try that ...
Frex
Frex
I have used some AP kit and its awsome, too expensive to have at home though and a PC sound card can do the same mesurments with less conveniance as the cheaper units. The artical claims the oscilator in the AP hardware is lower noise still and adjustable?!?!
I always read 'Anablog', also 'Powersource' and 'Scope Guru'
This was a very interesting one, replies include both Bob Pease and Jim Williams himself!
Bob's comment is like mine, I squeezed -150dB out of my old Sound Technology 1700B in 1992 with a few tricks (good enough for me). I talked with Jim about "distortionless" oscillators with distortion trims last time I saw him. If you can get a copy of his AES talk and especially his references you can get the whole story. It turns out, in my case, the way a Wein bridge "really" works was buried in an obscure text book I had at MIT. Jim's reference from HP labs covering the same issue is in his words, "The best piece of engineering he has ever seen".
Jim sent me a copy of the article. It was Bernie Oliver's cover article in the Apr.-June 1960 issue of the HP Technical Journal. The gist is you can't simply make a distortionless Wein bridge oscillator. Bernie argued one way and my text used it to explain the usefulness of Volterra math (comming essentially to the same answer). I can't wait to see the latest incarnation, I'm sure Jim has a few secret rooms with virtually unavailable exotic components.
analog scope in crossplot mode
Not being able to aford an AP just yet, can anyone point me to an article, book or reference on how to use a scope in crossplot mode to measure distortion?
'scopes and eyeballs are pretty poor in distortion resolution - better soundcards are really excellent in the audio frequency range
The EDN designer's companion
By Ian Hickman, Bill Travis
see page 188
link The EDN designer's companion
Distortion Measurement audio amplifiers
The bridge null techniques are useful but I think the spin on the above is measuring when you don't have a reference like the output of a DAC in response to a digitally perfect sine table lookup.
Is that "Modern Perspectives on Hewlett's Sinewave Oscillator" from the 125th convention?
Yes, Jim sent me copies of his references. He said he spent two years in doing the final settlingtime app note (LT #120). It was pretty over the top and if the oscillator is like that you will need to visit a lot more dumpsters.
For those who were wondering, here's a link to the Linear Tech Application Note:
http://cds.linear.com/docs/Application Note/an120f.pdf
Williams is one of those folks who seems to happily credit others for their great work.
I think Bob Pease was referring to AN-1671
www.national.com/an/AN/AN-1671.pdf
http://www.diyaudio.com/forums/equi...designs-new-super-oscillator.html#post2550648
page 188
carpin, I'm not quite sure why you're quoting me and the linking to this thread. Yes, I can read, and yes, I have read the whole thread from the start.
I was commenting on post no.8, by klewis:-
If you look at the OP's EDN link and scroll down a bit, you will see the following comment by Bob Pease:-
I was merely pointing out what I thought the source of Bob Pease's comment may be, to try and assist klewis.
Bob Pease commented:
I have been measuring op-amps with -159 dB of distortion, using an old Tek 2445 ANALOG Scope in Crossplot mode. I do this on the bench in my office because I don't have any A.P. equipment. I'm pushing past -164 dB next. / rap
If you got to 28mins, The Man Himself gives a quick crossplot demo.
www.youtube.com/watch?v=CecuJzG5Rrk
The long awaited article.
Test 18-bit ADCs with an ultrapure sine-wave oscillator - 2011-08-11 07:00:00 | EDN
EDN - Download
Not quite -160dB as it was rumoured, but the more human -100~-115dB.
Even then, I am sure Frex or others might still build one to test out if only as a tribute to Mr. Williams, whom we all miss ....
Patrick
EDN - Download
Patrick
- Design & Build
- Equipment & Tools
- Jim Williams designs a new Super Oscillator
