Hello,
Guys, i have just purchased Dry Film Photo resist , Around 200 ft, It was a 500 Ft roll. Me and my Another friend Shared the roll.
Now I want to share the film with Diyers from India, Just pay the shipping and packaging fees. Only 5Ft of film to 1 Member is free.
Happy Diy.
Happy Diy.
Be careful!
Purchased an inductance/capacitance/ meter from a
shop in Chunam lane (forgot the name of the shop, it
is on the left side when coming from Lamington road,
selling all kind of tools). Costed Rs 1350/-+VAT, no
warrantee. Later after few minutes saw the same meter in
Visha Electronics in Rs 950/-+VAT+warrantee. Luckily the
guy was professional enough to take it back. I got it
finally from Visha.
Do not know what to conclude from this...but be
careful!
Roushon.
finally from Visha.
careful!
Roushon.
Aluminum sheets source...
In case you like to make your own chasis (as I do
although difficult and time consuming) I purchase
aluminum sheets of different thicknesses from the
following shop:
Pavan Mehta
Honesty Steel
35/37 Bapu Khote Cross Lane
Gulalwadi
Mumbai-400003
Mobile: 9820495404
Tel 022 23461150
They will not cut in small pieces. But you can get it done
from `Bombay Cutter' very near to them. Pavan can
tell you the direction. A week back I got some sheets
cut. Fantastic job in a few minutes, primitive technology
they use and very cheap. The cutting was a nightmare
for me.
Roushon.
following shop:
Pavan Mehta
Honesty Steel
Gulalwadi
Mumbai-400003
Mobile: 9820495404
Tel 022 23461150
for me.
Roushon.
hello Guys,
For original transistors and good quality capacitors and vacuum tubes-Amar electronics After crossing the tunnel under bridge take left turn go straight , 2 0r 3 shops before masjid.
For relay Ramesh Electronics take right turn after lamington rd police station , just before end of lane.
Copper wire for inductors shop name manish opp champion rubber same lane as ramesh electronics.
Hope this helps.
Hope this helps.
Thanks!
Thanks Viki for your contribution. Although we walk around a lane 100
of times it really helps when someone pin point a particular shop for a
particular item.
Thanks again
Roushon.
particular item.
Thanks again
Roushon.
dear roshan,
i live in fatehpur in u.p. plz send me the adress from where can coaching to make sophisticated pcbs at my e mail khan.shahid251@gmail.com
thanking you.you ever masood.
Hi Viki,
Thanks for the info, much appreciated. What vaccum tubes have you bought from Amar? Is he pleasant to deal with?
cheers,
mymindinside
cheers,
mymindinside
Hi Viki,
cheers,
mymindinside
Yes , a very nice fellow,
I had purchased ecc88, and have ordered kt88 tubes. He himself doesn't keep the tubes but will get it from good sources. And rates pretty much good compared to others selling the same.
There is this shop Ambee Electronics at proctor rd, Chotani bldg sells ferrite cores for transformers and crossovers.
Mind it friends Amar Electronics can get you capacitors from Elna, Rubicon, Nichicon, But have to purchase minimum quantity which he said was about 20 to 25 pcs.
I purchased 10,000 uf 100v Capacitors brand Nippon Chemicon these capacitors are as good as nichicon. Has extremely good prices when compared to other shops in lamington rd.
I am looking for carbon film resistors does any body know any good place.
Purchased 2 LM3886TF National Semiconductor chips from Chip Components, this shop is in the lane after chunam lane
following shop:
Pavan Mehta
Honesty Steel
Gulalwadi
Mumbai-400003
Mobile: 9820495404
Tel 022 23461150
for me.
Roushon.
Roushon, can you post pictures and the prices ?
This thread is fantastic !!
Sorry!
Sorry! I have no pictures. The cuts are rectangular in size from a big
3mm sheet. So there is not much to see. I am sure you can get
some fancy cut also from Bombay cutter. You have to contact them.
Aluminum sheet Rs 215/- per kg. The charge for the cutting depends
on the job. I paid Rs 50/- to cut 8 different sizes pieces from a single piece.
Roushon.
Roushon.
dear roshan,
Sorry Massod I never dealt with sophisticated PCB. The PCB I make are
at the most double sided. I learnt it myself using the freeware
version of the Eagle software. You can download it from the site:
CadSoft Online: Download
The freeware version has limitations: at the most two sided and the
maximum size of the PCB is 3inch x 4inch. But if you purchase
the full version you can do anything.
Hope this helps.
Best wishes.
Roushon.
finally from Visha.
careful!
Roushon.
Got mixed up with the road name. The shop is on Shamrao Vithal
Marg, this is parallel to Chunam lane. The shop name is Rhythm
Electronics who took excessive price for the multimeter.
Roushon
Roushon
Thanks..
I had the misfortune to get hit by the fake transistor bug.
I bought 2SC2240 transistors from Roland Electronics at
Gujarati Galli, Koti, in Hyderabad. They turned out to be fakes,
and even the pinout and HFe are wrong. They are
exactly the same fakes as documented in this thread here -
Counterfeit 2SC2240 - AudioKarma.org Home Audio Stereo Discussion Forums
This is a very useful information. Many of us at times
looked for LM3886. I had to finally import it some years
back. Is the IC available always in Chip Component? In
case you know kindly post.
Roushon.
Roushon.
For how much did you get it.
I inquired here @ pune its 250/- each. I guess that IC must be easily available. Is it a rear chip ?
- Design & Build
- Parts
- Parts in Mumbai (India)
