strictmachine
your speakers are fine (hopefully), the amp is not. I would send it back for a replacement.
Joe
Joe
Thanks for the reply Joe.
Oh dear, I bought it off a guy on flea bay. Getting a refund may prove a problem.
May have to write it off as a bad experience.
Unfortunately it puts me off getting another which is a shame as it is just what I wanted.
I just contacted the ebay seller telling him of the problem and this is his reply:
Hi, the 'pop' you hear is becuase of the power. It's a power amp. I've never haerd of speak cones popping out. The amp works fine... it's brand new. I think maybe your speakers are at fault??
The QC on the Lepai amps is pretty questionable. Reading through this thread you'll see lots of evidence of this in various iterations of the amp. I bought two A+ models from Parts Express and they have wildly different output levels. Fortunately PE was super helpful in getting the issue resolved. I think they must have had a fair amount of displeased purchasers of this unit so they don't hesitate to help the customer. If possibly I'd recommend buying from them directly and not from eBay sellers. You'll also get the newest version from them (but maybe you'd prefer the thru-hole versions of yore).
@ strictmachine: On my A+ units there's a little thump but nothing that concerns me. Have you popped the top on yours to check which model you have? If you think you'll have to chalk this one up to experience you might just try some of the mods found on this thread (especially if you have an older version). And if you don't consider yourself to be technically minded just think of the great satisfaction you'll feel upon completion... 🙂
You mention yours also make a thump. Do the cones of your speakers pop out too ?
Hi, i think it cant power a 2.1
i did buy 2 2020s, first one is a old 2020, i blew the rectifier diode with the evil, evil creative 4.8a transformer and i ordered another lepai, i did repair this one changing the diode
second one i received today is a lp-2020b board
its normal than the 2020 sounds louder than the 2020b ?
Hey there!
My friend is currently thinking about ordering this Lepai amp:
Lepai TRIPATH TA2020+ Amp Mini Hi-Fi Audio Amplifier | eBay UK
However, in his project his amplifier will be placed in a portable stereo, which most likely will be encountered with quite some heat as it will be taken out and played in the sun for several hours in a row.
Therefore, I thought that I would ask you ask if you have any ideas of improving the heat dissipation, as I do not think that the current aluminium enclosure will be sufficient enough at distribution heat away from the amp. It would suck to have your amplifier fried while you are out playing.
Thank you very much in advance 🙂
i dont think they are getting so much hot... i have an Class A/B amp with 30W and it goes just handwarm
Hi, I'm getting major distortion sounds one one channel or no sound at all. I've tried 3 different sets of speakers and 3 different power supplies. The other channel works fine. What should I be looking at to see what the problem is? I've had a look at the board and it all looks relatively clean and no noticeable mistakes.
Thank you.
Thank you.
Hey there!
It will not be a problem under any sircumstances at all. You can heat up the cabinet to 85 degrees celsius and it still won't be a problem.
What can shut the TA2020 chip down due to temperature overload is if the junction temperature exceeds 150 degrees celsius. And that can basically only occur if there's no heatsink attached to the chip at all and you're running 2 ohms speakers.
Can someone tell me the minimum and maximum Voltage i can use it with?
I plan to use LiIon 18650 pack, so the Voltage can range
8V-12,6V (3S) or 11V-16,8 (4S)
So i think 3s would be safe to use, but has lower power and usage time than 4s.
Anyone tested exactly?
I bought one of these units afew years ago, think it sounds awful!! is there much of a burn in period?
Hi, total newbie here - i hope you don't mind me asking a few questions.
I'm looking to convert the case from an old 60s transistor radio into an iPod dock, and thought a Lepai TA2020 would be perfect, but have the following questions:
On the new board with surface mounted components, would I still be able to remove and remount the On/Off switch, volume pots, speaker and minijack connections to fit the radio case?
Space is fairly tight - can I remove the board from the aluminium case and fit it into my radio, or is it necessary for heatsink or grounding etc.?
Would these full range drivers be suitable to be powererd by the Lepai?
Many thanks for any assistance you can offer,
Patrick
Patrick
In my experience it's best to have nothing or an LED & resistor connected to the fault pin. This helps protect the TA2020 IC. 🙂 Anything else is probably asking for trouble.OK, here is the relay protect circuit as best as I can trace it. It is all surface mount. The thing that concerns me is the connection between the fault/relay circuit and the overvoltage/mute circuit. In the case of Fault going high, I think this would 'toggle' the mute pin which resets the fault. But if the fault condition persists, will this lead to damage to the TA2020?
Even on the early Lepai's, I have no idea what they were trying to achieve with the diode connected to the fault pin, I always removed this diode after the TA2020 died on my Lepai.
I just received 2 units from PE, and they sound surprisingly good. Want to modify one if electronic gurus here can figure out the recommended mod to improve the sound.
gychang
That's exactly what I did in the end...
- Class D
- Lepai T-Amp with TA2020
