Mid Visaton TI100.I'm curious what you guys have found to be the most detailed driver you have used?
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
Low monacor sph250ctc.
MONACOR INTERNATIONAL : New products
High DT300.
Audax HM100Z0.
Ah yes, there is something a bit special about them. I do wonder if maybe I shouldn't have sold mine. They just need to be treated very carefully with regard to their enclosure and I didn't give them enough room to breathe. They still produced incredible imaging though.
Well, looks like they are back in production again anyhow, can get new models from Madisound which are presumably identical to the originals.
My TI100 are 4" to like the audax I think it is a good diameter for open sounding mid-reproduction.
What exactly does that mean?? "detailed"??
Lowest distortion?
Widest bandwidth?
Flattest in band response??
Tip up the highs and people think it is "detailed".
Not much of a trick in that. Works most of the time.
The best single driver I have ever worked with that is not on a horn was the Stage Accompany ribbon... probably because it was nearly flat, very wide bandwidth (it went flat past 20kHz.. - not that many can hear up there) and it was lower in distortion by an order of magnitude compared with other very good direct radiator drivers of any type... It did have vertical dispersion issues however... so no free lunch (yet). FYI usable range was from 1.5kHz. up.
So there is my "2 cents worth" of personal preferences and opinion... and as always, I am always right. 😀
_-_-bear
Lowest distortion?
Widest bandwidth?
_-_-bear
Audax HM100Z0.
Took the words out of my mouth, assuming we're limiting ourselves to dynamic magnetic drivers. If we don't, then there's the Hill and Ionovac drivers...
Lowest distortion?
Widest bandwidth?
_-_-bear
This is an important point of the matter isn't it? If it has a narrow dispersion, it stands a better chance of being more "detailed" all other things considered (in a typical room) since the direct to reverb ratio is that much higher.
Also, crank up the high end, more detail. Crank up 4 kHz, more vocal intelligibility which can sound like detail. So many factors.
If detail is the over-riding goal, design it to be free field headphones: near field listening, no near boundaries, relatively dead room, narrow dispersion, tweak the EQ.
The real question is: how far are you willing to push any of these trade offs? The question only really makes sense once you baseline the acceptable limits of these trade-offs, along with size and cost limitations. Then you know what class of transducers and box (or not) designs you can choose from.
Dave
Only heard them the once, and wasn't stunned. Still, it was on the US distributors stand at NAB for their after show party, and listening conditions weren't ideal. Nice hostesses though. 😉
It's a tie between TAD TM-1201 and Fostex FE208ES-R for me!
And they just happend to sound fabulous also, not only good looks...
Best and 'most detailed' mid & tweeter so far, Audax HM100Z0 and Raal 70-10D- currently in use (kludged) with a Hawthorne Augie. The B&G Neo 3 is also very detailed/clean sounding. B&G Neo 10 almost ready to try out with the Neo 3 and the Raal.
This is an important point of the matter isn't it? If it has a narrow dispersion, it stands a better chance of being more "detailed" all other things considered (in a typical room) since the direct to reverb ratio is that much higher. snip
FWIW this contradicts what Dr. Toole says in sound reproductions and my personal experience with different dispersion characteristics. People's perception of these small drivers being more detailed would also agree with the research, but you are right--many factors come into play here. I thought my 4" metal cones on an OB were extremely detailed, but they also sounded bright on a lot of recordings. On axis was flat, of axis had a big 2-4k bubble(roughly). I don't use those anymore......
Dan
Some people mistake a bright system for being detailed. I am not talking about this. I am talking about drivers that will resolve the most minute details and timbers in the range they play in. I personally feel this is dominated by great temporal response followed by low distortion but there are many factors that are involved.
I know the Seas W22 very well, having used it for more than 10 years, also in open baffle. Its very good, but its beaten by the B&G RD-75, with a very large margin.
Question about Audax HM100Z0, what kind of X/O's are you using? can it be used without like the 6" jantzen/dynavox?
ps Hard to get hold of, can only see one place in europe selling them
Yes, actually detailed and perceived detail may not be the same thing. The question is what is what and how to separate the 2? If the FR is smooth, the temporal response is fairly fast and the low lever distortion of modern drivers renders it moot. Without detailed graphs for support, this conversation is meaningless.
Dan
- What has been the most detailed driver you have worked with?
