Based on Hugh Dean's AKSA 55
"wonder if those improved sound quality in any sims"
That's a oxymoron if I ever heard one ! 😀
Realistically , the on- semi (njw/mjl's) models will give the lowest PPM in a typical "blameless" simulation.
I am using a new pair (Sanken 2sc3263/2sa1294- below 1) , I could say they "sound better" but I know better .... they are just better matched and are especially made for audio.
These fine pieces of sand are nearly identical to 2sc5200's with a slightly higher SOA @60V.
OS
OS,
You have far too much energy. I want some.
I have always built AKSAs with twin, independent power supplies for the very reason you identify. Improves crosstalk, and thereby, imaging.
Hugh
If I could only trade energy for $$ , I'd be rich.. 😀
#2 in my above PSRR examples will match a dual supply with a lowly single supply. (in listening .. too 🙂 )
The 3'rd one is just pure overkill as far as listening goes. Can't discern the improvement , but what the hell :mischiev: .
Listening to a lot of classic rock , the L - R imaging is very apparent ... they "play with your head" in this genre (YES , Alan Parsons, Floyd) . A low PSRR main amp will be "unconvincing" when compared to a good highly regulated headphone amp. You have 2 choices ... design a VERY high PSRR amp to match with the cheap single supply (OEM style) , or augment the lower PSRR with cap multipliers or dual supplies. I opt to use both methods.
Dual supplies with multipliers (for the IPS/VAS) would be "the cat's meow" 🙂🙂
OS
OS
Which wan,s are the Fake,s?
In a 5 channel HT amp as "modules" with a single PS , one might have issues.
I have a plan to make a power supply with single 20A EI transformer, in a separated wooden cabinet that will act as a "table" for my amps (4 or 6 channels). Beside the ease of operation when the heavy PS is "in the table", this way I separate the signal from the nasty PS interference. Later I was thinking about buying another 20A for dual supply. But now I think I have to abort that plan 🙁
Good source of genuine Sanken OTs
Hi OS,
It is OOT but I could not resist.
I bought a broken Yamaha AV amp from eBay for $20 last week. The amp does not power on, I suspected that the standby power transformer is broken, however the main Transformer is tested OK, so is the main filter capacitor.
The spec of this amp (HTR-5840) says it is rated at 6x 85W RMS.
Inside the Yamaha is 6 pairs (12 pieces) of these Sanken babies. I reckoned it is a good buy for 20 bucks and it will be my next project - retrofit this amp with some decent diy boards.
Your A1294/C3263 are better than the Sanken in my Yamaha, it is LAPT (Multi emitter for High Frequency) and higher power & Ic. The fonts on your Sanken is similar to mine, so it is a good indicator.
Cheers, Stanley
At the local price of even these MT100 Sankens, I'm surprised any OEMs used them.
Especially not as they often were even in "budget" music centre bass channels.
Whether for the BAKSA or any small amp, Os, what are you expected to pay for those in the US?.
Hi OS,
Cheers, Stanley
So match to the Similarity.
Yamaha RX-V2090
OT End.😀
I wonder how this amp would benefit from some cap multipliers ? My sim's show barely adequate PSRR. 🙁
Hi ostripper,
I think I mentioned earlier in the thread that I intend to try the JLH ripple eaters on the front end. Anyway, here is a page of things I intend to try.
http://users.tpg.com.au/gerskine/greg/b-aksa 55-07.htm
Here's the info on the JLH ripple eaters. They do have a cap multiplier on the output. These are already designed built and tested by numerous people locally and internationally. sandyK for example has been using them for at least 5 years (probably longer). As far a I know no one has used them on AKSA style amps.
http://users.tpg.com.au/gerskine/greg/jlh add-on shunt regulator.htm
regards
$2.37USD at Newark for both sexes. About the same as my favorite on- semi NJW0281/0302's @ mouser. 😎
MT (100-200) packaging is overpriced , I did not know this .. but a mt-200 is just a repackaged to-3p (below) that they charge wayyyyy too much for. I have replaced mt-200's with on's NJW line , just drill the holes. 🙂
OS
Hi ostripper,
regards
Nico RAS uses his own version of "ripple eaters" in his amps. You don't need anything that serious for this amp. I use a C-R-C for my drivers , the cap mult's for my IPS/VAS (all fed from a separate 68-0-68V supply). Even with 2v or more ripple on the "dirty" OPS supply ,(which NFB takes care of nicely) , I can get close to the 3'rd (-120+ db PSRR) plot I posted before.
Output stages can take "dirty" rails , input stages like clean ripple- free environments. The power supply is just as important as the design of the amp.
Below 1 is the simple multiplier schematic - pix 2 is the CRC (68-0-68v)... The "dirty" 60v OPS supply is behind it. 😀
All works nice with a 55 or my BX (similar bootstrap amp)
OS
Hi homemodder.
I only bought 5 of each from RS. As far as I can tell, they are good transistors.
I built Dr. Bora's Sigma Amp: http://bas.elitesecurity.org/SIGMA-Schematic.pdf with them. The Sigma amp sounds good & I guessed that is what matters.
The parts are E-grade, I measured the Hfe: C3601 ~ 130, A1407 ~ 150.
I guessed that the stock at RS will not last very long given that On-semi now owns Sanyo and the main applications for these transistors are:
· Ultrahigh-definition CRT display.
· Video output.
· Color TV chroma output.
Attached is a picture.
Cheers, Stanley
After magnifying your pic to better see the details on those parts, I can say they are genuine. I would buy them all at that price, 😉
