Parasound JC3 Phono
As the folded cascode was published in other articles in 1969 or so, I doubt that the patent is actionable, at least. However, the use of a folded cascode single differential gain stage appears to be first in this specific op amp in 1971. Any earlier cites?
I have not found the book yet about surround sound from two channels but this guys claim to be able to do it with ONE channel only.
OK, Scott, with processing.
http://www.swissaudec.com/pdf/FAQ_Home.pdf
Gotta have that "professional" recording studio in your IPHONE.🙂 As I said before Bob Adams showed me a circuit with a cheap dual op-amp and a pot that moved the image around your head and back again.
EDIT- Read more, a real Swiss Army Knife product, even improves doppler ultrasound. No "world wide" patents found yet.
"The MAX9632 is a low-noise, precision, wide-band operational amplifier that can operate in a very wide +4.5V to +36V supply voltage range. The IC operates in dual (±18V) or single-supply mode (36V)."
No simplified Schematic in the data sheet 🙁
Rgds
James
Their explanation of how it works seems to boil down to:
a) Stereo can be reconstructed from sum and difference signals (duh!)
b) Every year electronic devices get smaller
c) Most FM broadcasts are still mono
d) Sometimes bad weather adversely affects TV reception
e) Something about a patent
Don't think I'll invest just yet 🙄
