How to build the F5
NP gave all his designs in public ;
anyone thinking that high res pictures at 6moons and few other places are published without his blessings ?
so - if he is certain that 300VA toroid + 8 x 15mF/25V is good enough for 160W of dissipation and 4K of greenies , I have no objection .
that doesn't stop me to use 2 x 250VA or even 2x400VA toroids and (4+4)x 33mF/25V for my Papamp
there is always need for book and calc and some brain ; but sometimes too much of a brain isn't smartest thing to have :rofl:
worst drek gadgets I had "pleasure" to see and/or repair were over-engineered piece of drek , not result of bean-counter's efforts
usually bean-counter engineers are way more capable than spoiled brat ones .
just for illustration - absolutely worst radio production (mix) deck I had opportunity to work with , see and repair - is one made by ( now defunct) local factory , called Lola Audio ; full with Penny Giles , Neutrik , Alps , Philips , etcetera jewels ..... it sounds as drek , works the same , buzz the same ....... ground loops , not enough headroom ......
and I always had a thoughts how decent and clever Studer engineers could make 3 proper decks with same amount of hardware , all whistles and bells included
so - take NP's visible work as shown path - " go , boy - make that better for your self ; I have other ,more important and fun , things to do . "
please note that Panasonic have about a hundred different 25V variations, within the same type, and different prices
the type used in FirstWatt is one the most expencive of those
not at all cheap for a 'consumer' buying just a few
buy a factory box of 500 direct, and its a different price
I think FW uses Pansonic TSUP series 85C caps. About $3-4 each in small quantities.
Me used 25Vdc TSHA Panasonics (105C) in the Alley-J, still seem to hold their liquor (very well vented).
Btw, on really pretty 300VA's from a groupy shag at the German forum, same blue encapsulated ones as used in the Tessendorf power amps.
I can't imagine there would be a lot of difference between two different Panasonic snapins. I think this was discussed in the F5 thread like three years ago. At the time the only 22x50mm 15,000uf cap with 85c rating was one from the TSUP series.
Hey, i'm Dutch, i shag around.
Ha, but bet you a nickel i can name 15 minimum part numbers, type, manufacturer, source adress of this one : http://www.tessendorf.de/images/classabig.jpg
(speaking of Fuk-U-shima, seen a CRC with Roederstein EY electrolytics and MPC71 metalband resistors before ?)
now I know why ya Klompenwearing ppl are so wakoo , even your MotoGP is different to all other - sole one running on Saturday ( instead on Sunday , as in other parts of brownie globe ) , so that you are free for early Sunday shag :rofl:
gimme a brake - that's just filthy rich version of MF A1 drek
regarding MPC - every second mediocre wallmart japamp have them ; maybe I must be impressed ?
speaking of ....... MPC in CRC :clown:
It did make sense when I wrote it, I swear. I'm not going to pretend I know what I'm doing, thats why I asked 🙂
I was under the impression that wiring the dual secondaries in parallel allowed twice the current delivery at the same voltage. Pass recommends a unit capable of delivery 10A peaks so.......... 1=8 ~ 2=16?
Heeeeeeelp.... I only need to buy the transformers and I can start testing / electrocuting myself ?!?!?!?
cheers
Dean
Doesn't he recommend that peak current for a stereo amp with one transformer? Thus one transformer per channel should be just fine. Just be sure the transformer you use will regulate well so your rail voltage doesn't sag.
you need two secondaries to have symmetric PSU
F5 , in stock form - with 2x18Vac secondaries , will have around +/-22V after rectifier and smoothing caps .
+/-22V means - symmetric PSU , so there is no way that you can use parallel anything .
Papa use ~ 300VA xformer common for both channels , but xformer is of decent quality .
dunno is linked one of same quality , but if you use 2 of them ,there is possibility that they will be fine , even if of lesser quality than FW stuff .
yes - buy them and enjoy .
but - you really need to learn some basics ( how to read schematic , for start) - not to please me or anyone , but to be able to make something ( with help ) , without hasta la vista babe ......
"The power supply of the tested amplifier is +/-24 volts and should be rated at 6 amps
continuous duty, and more than 10 amps peak per channel".
I read this as a literal guide and was looking for a toroidal that delivered as such.
Again, I am happy to just use what works, but its going to be cheaper to buy from aus so i need to find the right device on there site.
https://www.tortech.com.au/
Cheers
Dean
