Zenquito Variants - SK170 SJ74 ...drive 2SK1058
Experiences with using 2SK170 + 2SJ74 for Zenquito ?
How about voltage? SJ74 is max 25 Volt. SK170 = 40 Volt, alright.
For +/- 34 Volt I will need some cascoding.
With bipolar? Maybe BC550C/BC560C?
The Zenquito version I have in mind, see Schematic below.
Uses 2SK246 + 2SJ103 and I can not easily get those.
But I can find supplier in my country for SK170/SJ74.
Thanks for any useful information for the interesting Zenquito amplifier.
Muchos Regardas, Lineup
No problem with the higher transconductance of these devices. There will just be some more gain at the first stage and so, some more open loop gain. No stability issues. Actually, there is many version of the Zenquito/Buzquito using these too.
Here a model with current mirrors and cascode...a fully scalable design. Just add output sets the needed SOA. It SIM's with rather low distortion and also a good distortion distribution..!!
But must still say that I have a little problem with the split and having complimentary parts handling the signal.
The one J-fet amplifier you previously pulled out of the hat....I fancy that...🙂
Very nice circuit Lineup! I know that you like very much symmetrical input stages and you are right on this.
We could use the channel bridging mode to increase the output power, keeping thus the supply voltage in low level instead cascading transistors. In such a case, we need 4 channels (instead the ordinary two) for making a fully symmetrical (balanced) from input to output stereo amplifier.
Just an idea, because i have a 2 X 21V / 200VA toroid surplus which can provide an output power (according to bridge mode) of 2 X 70 Wrms / 8 Ohms.
I see that, nevertheless, the cascoding transistor is a voltage amplifier. By adding another voltage amplifying stage and altering the common source stage into source follower the design is made more mediocre compared to the original Zenquito. This amp will behave very differently.
I like the MiiB 60/50 Volt variant.
The original Zenquito can be made in different flavours.
Lower voltage, higher voltage, Class AB, Class A.
See here: 2A & DIY
Personally I like amplifiers with lower power.
It is enough for most cases.
It is striking how simple amplifiers can be designed
with Lateral MOSFET, 2SK1058/2SJ162.
If I was to build a power amplifier I would go this way.
I realise this is an old thread but lineup could you do me a favour?
Could you sym this schematic for me?
I'm interested if you could sym it with 50V supplies with 2 pairs of 2sk1058 and such at 1W and full power into 4 and 8ohm? If you could that would be really appreciated!
Thanks!
.step v=0.1
Fourier components of I(load)
DC component:0.00104633
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 1.000e+03 2.632e-01 1.000e+00 179.96° 0.00°
2 2.000e+03 3.269e-07 1.242e-06 91.91° -88.05°
3 3.000e+03 3.966e-07 1.507e-06 -171.78° -351.74°
4 4.000e+03 2.717e-09 1.032e-08 67.16° -112.80°
5 5.000e+03 3.363e-09 1.278e-08 17.35° -162.60°
6 6.000e+03 5.825e-09 2.214e-08 27.88° -152.08°
7 7.000e+03 5.835e-09 2.217e-08 20.89° -159.07°
8 8.000e+03 6.166e-09 2.343e-08 11.85° -168.11°
9 9.000e+03 6.636e-09 2.522e-08 12.96° -166.99°
Total Harmonic Distortion: 0.000195%
.step v=0.2
DC component:0.00104536
1 1.000e+03 5.263e-01 1.000e+00 179.96° 0.00°
2 2.000e+03 1.291e-06 2.452e-06 92.15° -87.81°
3 3.000e+03 3.219e-06 6.116e-06 -171.59° -351.55°
4 4.000e+03 2.711e-08 5.150e-08 156.68° -23.28°
5 5.000e+03 2.037e-08 3.871e-08 172.50° -7.46°
6 6.000e+03 2.661e-08 5.056e-08 171.82° -8.14°
7 7.000e+03 3.157e-08 5.998e-08 164.73° -15.23°
8 8.000e+03 3.562e-08 6.767e-08 172.97° -6.98°
9 9.000e+03 4.218e-08 8.013e-08 178.62° -1.34°
Total Harmonic Distortion: 0.000659%
.step v=0.3
DC component:0.00104379
1 1.000e+03 7.895e-01 1.000e+00 179.96° 0.00°
2 2.000e+03 2.836e-06 3.592e-06 91.09° -88.87°
3 3.000e+03 1.090e-05 1.380e-05 -171.35° -351.31°
4 4.000e+03 4.381e-08 5.549e-08 117.63° -62.33°
5 5.000e+03 4.914e-08 6.224e-08 36.84° -143.11°
6 6.000e+03 1.831e-08 2.320e-08 23.51° -156.45°
7 7.000e+03 1.760e-08 2.230e-08 24.20° -155.76°
8 8.000e+03 2.185e-08 2.768e-08 35.44° -144.52°
9 9.000e+03 2.331e-08 2.953e-08 31.64° -148.32°
Total Harmonic Distortion: 0.001426%
.step v=0.4
DC component:0.0010417
1 1.000e+03 1.053e+00 1.000e+00 179.96° 0.00°
2 2.000e+03 4.818e-06 4.577e-06 90.13° -89.82°
3 3.000e+03 2.611e-05 2.480e-05 -171.18° -351.14°
4 4.000e+03 1.591e-07 1.511e-07 130.02° -49.94°
5 5.000e+03 1.473e-07 1.399e-07 33.94° -146.02°
6 6.000e+03 1.149e-08 1.091e-08 -52.51° -232.47°
7 7.000e+03 4.603e-09 4.373e-09 -126.04° -306.00°
8 8.000e+03 4.989e-09 4.739e-09 -29.17° -209.13°
9 9.000e+03 9.521e-09 9.046e-09 -2.03° -181.98°
Total Harmonic Distortion: 0.002522%
.step v=0.5
DC component:0.00103927
1 1.000e+03 1.316e+00 1.000e+00 179.96° 0.00°
2 2.000e+03 7.028e-06 5.342e-06 88.44° -91.52°
3 3.000e+03 5.172e-05 3.931e-05 -170.98° -350.94°
4 4.000e+03 4.977e-07 3.783e-07 132.93° -47.03°
5 5.000e+03 4.375e-07 3.325e-07 38.91° -141.05°
6 6.000e+03 3.031e-08 2.303e-08 -107.99° -287.95°
7 7.000e+03 6.282e-08 4.774e-08 -172.09° -352.05°
8 8.000e+03 6.861e-08 5.215e-08 172.31° -7.65°
9 9.000e+03 7.181e-08 5.458e-08 171.73° -8.22°
Total Harmonic Distortion: 0.003968%
.step v=0.6
DC component:0.00103688
1 1.000e+03 1.579e+00 1.000e+00 179.96° 0.00°
2 2.000e+03 8.900e-06 5.637e-06 84.98° -94.98°
3 3.000e+03 9.113e-05 5.773e-05 -170.71° -350.67°
4 4.000e+03 1.307e-06 8.281e-07 130.24° -49.72°
5 5.000e+03 1.275e-06 8.075e-07 37.13° -142.83°
6 6.000e+03 1.333e-07 8.446e-08 -70.67° -250.62°
7 7.000e+03 1.588e-07 1.006e-07 -162.22° -342.18°
8 8.000e+03 1.223e-07 7.747e-08 169.18° -10.78°
9 9.000e+03 1.152e-07 7.296e-08 172.72° -7.24°
Total Harmonic Distortion: 0.005801%
.step v=0.7
DC component:0.00103534
1 1.000e+03 1.842e+00 1.000e+00 179.96° 0.00°
2 2.000e+03 9.336e-06 5.069e-06 76.49° -103.47°
3 3.000e+03 1.487e-04 8.073e-05 -170.33° -350.29°
4 4.000e+03 3.309e-06 1.797e-06 127.68° -52.28°
5 5.000e+03 3.356e-06 1.822e-06 36.32° -143.64°
6 6.000e+03 5.912e-07 3.210e-07 -53.64° -233.59°
7 7.000e+03 4.368e-07 2.372e-07 -146.12° -326.08°
8 8.000e+03 2.191e-07 1.190e-07 157.43° -22.53°
9 9.000e+03 1.243e-07 6.748e-08 152.40° -27.56°
Total Harmonic Distortion: 0.008093%
.step v=0.8
DC component:0.00103668
1 1.000e+03 2.105e+00 1.000e+00 179.96° 0.00°
2 2.000e+03 6.990e-06 3.321e-06 38.78° -141.18°
3 3.000e+03 2.312e-04 1.098e-04 -169.78° -349.73°
4 4.000e+03 8.575e-06 4.074e-06 125.32° -54.64°
5 5.000e+03 8.655e-06 4.112e-06 36.04° -143.92°
6 6.000e+03 2.300e-06 1.093e-06 -49.30° -229.25°
7 7.000e+03 1.532e-06 7.280e-07 -137.98° -317.94°
8 8.000e+03 7.084e-07 3.366e-07 145.38° -34.58°
9 9.000e+03 2.751e-07 1.307e-07 79.06° -100.89°
Total Harmonic Distortion: 0.011005%
.step v=0.9
DC component:0.00104797
1 1.000e+03 2.368e+00 1.000e+00 179.96° 0.00°
2 2.000e+03 2.257e-05 9.531e-06 -50.50° -230.46°
3 3.000e+03 3.546e-04 1.498e-04 -168.79° -348.75°
4 4.000e+03 2.637e-05 1.114e-05 123.21° -56.74°
5 5.000e+03 2.552e-05 1.078e-05 36.06° -143.89°
6 6.000e+03 1.087e-05 4.591e-06 -48.25° -228.21°
7 7.000e+03 7.770e-06 3.282e-06 -135.02° -314.97°
8 8.000e+03 4.545e-06 1.920e-06 139.65° -40.30°
9 9.000e+03 2.978e-06 1.258e-06 53.73° -126.23°
Total Harmonic Distortion: 0.015101%
.step v=1
DC component:0.00108826
1 1.000e+03 2.630e+00 1.000e+00 179.96° 0.00°
2 2.000e+03 9.579e-05 3.642e-05 -66.43° -246.38°
3 3.000e+03 5.529e-04 2.102e-04 -167.28° -347.23°
4 4.000e+03 7.586e-05 2.884e-05 121.96° -58.00°
5 5.000e+03 6.698e-05 2.547e-05 35.87° -144.09°
6 6.000e+03 2.925e-05 1.112e-05 -48.71° -228.67°
7 7.000e+03 1.594e-05 6.060e-06 -135.53° -315.48°
8 8.000e+03 2.774e-06 1.055e-06 134.97° -44.98°
9 9.000e+03 3.851e-06 1.464e-06 -125.88° -305.83°
Total Harmonic Distortion: 0.021718%
.step v=1.1
DC component:0.00113792
1 1.000e+03 2.893e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 1.757e-04 6.073e-05 -68.60° -248.55°
3 3.000e+03 7.902e-04 2.732e-04 -166.62° -346.57°
4 4.000e+03 1.025e-04 3.543e-05 121.70° -58.25°
5 5.000e+03 8.378e-05 2.896e-05 34.90° -145.05°
6 6.000e+03 7.929e-06 2.741e-06 -52.96° -232.91°
7 7.000e+03 9.812e-06 3.392e-06 50.32° -129.64°
8 8.000e+03 2.673e-05 9.241e-06 -40.86° -220.82°
9 9.000e+03 2.356e-05 8.143e-06 -129.09° -309.05°
Total Harmonic Distortion: 0.028386%
.step v=1.2
DC component:0.00117725
1 1.000e+03 3.155e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 2.259e-04 7.161e-05 -68.94° -248.89°
3 3.000e+03 1.069e-03 3.387e-04 -166.42° -346.37°
4 4.000e+03 8.817e-05 2.794e-05 121.82° -58.13°
5 5.000e+03 8.957e-05 2.839e-05 33.21° -146.75°
6 6.000e+03 3.900e-05 1.236e-05 131.12° -48.83°
7 7.000e+03 3.262e-05 1.034e-05 45.23° -134.73°
8 8.000e+03 4.629e-05 1.467e-05 -44.38° -224.33°
9 9.000e+03 1.846e-05 5.850e-06 -137.16° -317.12°
Total Harmonic Distortion: 0.034916%
.step v=1.3
DC component:0.00120097
1 1.000e+03 3.418e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 2.439e-04 7.136e-05 -68.82° -248.78°
3 3.000e+03 1.385e-03 4.053e-04 -166.47° -346.42°
4 4.000e+03 5.081e-05 1.487e-05 122.92° -57.03°
5 5.000e+03 8.255e-05 2.416e-05 32.33° -147.62°
6 6.000e+03 7.768e-05 2.273e-05 128.38° -51.57°
7 7.000e+03 5.856e-05 1.714e-05 40.28° -139.68°
8 8.000e+03 3.503e-05 1.025e-05 -51.16° -231.11°
9 9.000e+03 1.340e-05 3.920e-06 -145.95° -325.91°
Total Harmonic Distortion: 0.041363%
.step v=1.4
DC component:0.00121555
1 1.000e+03 3.680e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 2.443e-04 6.640e-05 -67.80° -247.75°
3 3.000e+03 1.727e-03 4.694e-04 -166.57° -346.53°
4 4.000e+03 8.916e-06 2.423e-06 151.49° -28.46°
5 5.000e+03 5.468e-05 1.486e-05 31.99° -147.96°
6 6.000e+03 9.790e-05 2.660e-05 126.89° -53.06°
7 7.000e+03 8.530e-05 2.318e-05 39.17° -140.78°
8 8.000e+03 6.794e-06 1.846e-06 -89.03° -268.99°
9 9.000e+03 1.524e-06 4.141e-07 88.41° -91.54°
Total Harmonic Distortion: 0.047561%
.step v=1.5
DC component:0.00122125
1 1.000e+03 3.942e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 2.297e-04 5.827e-05 -65.07° -245.02°
3 3.000e+03 2.097e-03 5.320e-04 -166.64° -346.59°
4 4.000e+03 4.144e-05 1.051e-05 -69.98° -249.93°
5 5.000e+03 1.244e-05 3.157e-06 22.63° -157.32°
6 6.000e+03 1.059e-04 2.686e-05 127.98° -51.98°
7 7.000e+03 9.876e-05 2.505e-05 40.12° -139.83°
8 8.000e+03 3.135e-05 7.953e-06 142.20° -37.75°
9 9.000e+03 2.960e-05 7.508e-06 47.94° -132.01°
Total Harmonic Distortion: 0.053670%
.step v=1.6
DC component:0.00121575
1 1.000e+03 4.204e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 1.974e-04 4.696e-05 -61.05° -241.00°
3 3.000e+03 2.504e-03 5.956e-04 -166.81° -346.76°
4 4.000e+03 9.117e-05 2.169e-05 -66.64° -246.59°
5 5.000e+03 2.656e-05 6.317e-06 -143.36° -323.31°
6 6.000e+03 1.035e-04 2.462e-05 128.17° -51.78°
7 7.000e+03 9.620e-05 2.288e-05 38.78° -141.17°
8 8.000e+03 5.714e-05 1.359e-05 136.89° -43.06°
9 9.000e+03 5.570e-05 1.325e-05 48.41° -131.54°
Total Harmonic Distortion: 0.059915%
.step v=1.7
DC component:0.00119304
1 1.000e+03 4.466e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 1.484e-04 3.323e-05 -53.37° -233.32°
3 3.000e+03 2.961e-03 6.631e-04 -166.92° -346.87°
4 4.000e+03 1.404e-04 3.144e-05 -64.21° -244.16°
5 5.000e+03 6.279e-05 1.406e-05 -148.40° -328.35°
6 6.000e+03 9.878e-05 2.212e-05 125.82° -54.13°
7 7.000e+03 8.359e-05 1.872e-05 35.42° -144.53°
8 8.000e+03 7.439e-05 1.666e-05 136.61° -43.34°
9 9.000e+03 8.332e-05 1.866e-05 45.02° -134.93°
Total Harmonic Distortion: 0.066588%
.step v=1.8
DC component:0.00115807
1 1.000e+03 4.727e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 8.648e-05 1.829e-05 -26.75° -206.70°
3 3.000e+03 3.470e-03 7.341e-04 -166.95° -346.90°
4 4.000e+03 2.017e-04 4.267e-05 -64.50° -244.45°
5 5.000e+03 8.276e-05 1.751e-05 -153.71° -333.66°
6 6.000e+03 9.121e-05 1.929e-05 126.55° -53.40°
7 7.000e+03 5.598e-05 1.184e-05 27.20° -152.75°
8 8.000e+03 8.465e-05 1.791e-05 134.81° -45.14°
9 9.000e+03 9.831e-05 2.080e-05 45.95° -134.00°
Total Harmonic Distortion: 0.073668%
.step v=1.9
DC component:0.00109999
1 1.000e+03 4.989e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 9.077e-05 1.820e-05 50.81° -129.14°
3 3.000e+03 4.053e-03 8.125e-04 -166.83° -346.78°
4 4.000e+03 2.709e-04 5.431e-05 -64.64° -244.59°
5 5.000e+03 8.888e-05 1.782e-05 -164.84° -344.79°
6 6.000e+03 8.653e-05 1.735e-05 124.84° -55.11°
7 7.000e+03 2.605e-05 5.222e-06 -15.87° -195.81°
8 8.000e+03 8.799e-05 1.764e-05 133.10° -46.84°
9 9.000e+03 1.113e-04 2.231e-05 46.51° -133.44°
Total Harmonic Distortion: 0.081539%
.step v=2
DC component:0.00101845
1 1.000e+03 5.250e+00 1.000e+00 179.95° 0.00°
2 2.000e+03 2.259e-04 4.303e-05 82.39° -97.56°
3 3.000e+03 4.718e-03 8.987e-04 -166.44° -346.38°
4 4.000e+03 3.584e-04 6.827e-05 -65.00° -244.94°
5 5.000e+03 7.933e-05 1.511e-05 169.36° -10.58°
6 6.000e+03 7.918e-05 1.508e-05 122.42° -57.53°
7 7.000e+03 6.673e-05 1.271e-05 -96.63° -276.58°
8 8.000e+03 8.248e-05 1.571e-05 134.77° -45.18°
9 9.000e+03 1.243e-04 2.368e-05 51.48° -128.47°
Total Harmonic Distortion: 0.090313%
