I'm actually wondering the same thing. It would be my estimate that these replica piezos should have a lower value resistor. Between 33 and 47 Ohms seems like a more optimal value just from experience with other similar piezos. Of course, if you've measured them and calculated 150 Ohms to be the best and confirmed that with listening tests, then I guess it's the right value for those too.
I didn't test them as I don't have the equipment to do it. But I guess I'll put a 40-50 ohm resistor on them and hope for the best (I think you said somewhere that people often tend to use too low resistor values). If they sound bad, I'll experiment with higher values.
Still, have you figured out what the optimal solution is for the original piezos for the new design when talking about the resistor value?
http://www.sperbits.ch/foto.JPG
I am almost finished with my boominator. As mentioned by a lot of other people.. WOW it plays loud 🙂 - However i might a slight change in the design compared the original design (i regret most of my desissions 😀).. However i have some questions regarding the drop in performance made from theese dessions/mistakes:
1: i did not make the center brace.. will this affect the sound in a noticeable way or is the purpose of the bracing rather to make the boominator indestructable?
2: i assume i have a lot more airgaps different places around the system.. For instance i did not glue the entire box together but made a removeable lid which i fasten by some hinges as shown on the picture. (i added a gasket between the lid and the box in order to seal it as much as possible). Is this sealing allright and how much does it matter?
3: I painted the tweeters (the routing for the holes on the tweeters were my first routing ever so there was a gap which i fixed with some extra paint and some pollyfilla... that looked horrible so i decided to paint them as well, knowing that i changed the response of the tweeters by adding some mass to them - the layer of paint on the tweeters is rather thin).. is this a major concern.. should i replace them?
the 3 things listed above are my biggest concern for my boominator.. i know my questions are a bit loose.. but some advice regarding where i should try do some damage controll will be much appreciated 🙂
1. and 2. are related. The point is to make the cabinet as rigid as possible and 100% air tight under all conditions. The very point is that it's the speakers and not the cabinet that's supposed to vibrate and thereby make sound. The more rigid and more airtight the cabinet is the better sound in general, and better bass in particular.
I would suggest immidiately pulling of those hinges off and glue the cabinet together is it's supposed to be, and making sure there's absolutely no other holes or air gaps than the port itself.
3. Your choice. I'm pretty sure that no matter how much paint you've spray on none of it has hit the actual membrane that is in the back.
Ive been thinking all day about how to remove the hinges, and still make the box look somewhat cool. I decided not to remove them since i used so much time in painting the box. Glueing the box furthermore gives me no means of replacing the elctronics 😀 !! (the lid is pressed with great force agains the sealing gasket so i guess the problem is not catastrophic???) I will instead build another version of the boominator for a friend, paying more attention the details in your design...
I added some bitumen different places on the inside of the box and then i sealed all small holes on the inside with some sealant rubber... I think it sounds awesome!!, but this is my first audio project ever so i have nothing to compare it to. Even though i decided not to go with your answer, then thank you anyhow. Knowledge for future projects is allways well appreciated. "Copy Saturnus audio knowledge initiate"
It will probably still sound very good 🙂 But as previously mentioned by Saturnus himself, the boominator design is somewhat perfect in all aspects. Changing the design will only degrade quality (even though the project will still sound awesome when superdrunk). 😀
It5's not a big deal to add a few big bolts, the kind with plastic knobs on them meant for tightening by hand rather than with a wrench. You just need tio install some blocks of hard plastic or aluminum inside, screwed into the walls, and drill and tap them out to fit the bolts, and also drill matching holes in the lid. With six or so, you can really fasten the lid down quite tightly, but still make it pretty easy to access the inside. If you pick some cool-looking ones (check your surplus outlets), they can even add to the aesthetic. Like this:
McMaster-Carr
--Buckapound
McMaster-Carr
--Buckapound
McMaster-Carr
--Buckapound
is hard plastic a better solution than a rubber gasket? my lid is very tightfully mounted.. but that is just from a "craftsman" point of view (i cannot rock the lid by hand at least)... i got no clue on how airtight it is and i dont know how to test for it either?
You can test how tight it is by putting it on full volume and cover the port. If any air leaks out (or in) it's not tight enough.
If you're worried about appearance you might want to turn it over 180 degrees and install the panel from the top in the bottom instead. And then do as Buckapound suggests, with the rubber gasket still in place. Because then any bolts will not be visible, and if you need to, you can just turn it over to get access to the inside.
That's actually the reason why the hole in the electronics compartment Boominator design is on the bottom. Because you practically never have to access it, so you can just as well have it on the bottom where no one can see it. That also have the side effect of should there be spilled water into the venting holes, from rain or just drunk people, it will flow out of the bottom hole without harming anything inside.
The hard plastic was for a block inside the compartment to screw the bolts into.. You still need a rubber gasket around the edge..
You can see how i did it in my boominator here: http://www.diyaudio.com/forums/clas...ab-ultimate-party-machine-74.html#post2295893
It fits very snug and tightens hard enough so that no air escapes whatsoever 🙂
Either it's me or it's not easy to find a sealing gasket in rubber online. It has to be around 10 mm in thickness. Closest thing I've found is some weird site selling swimming equipment. They have a latex tube og 14 mm. I guess that could work, but does anyone know where to get this? Can you just normally get this at a hardware store or something like that?
Maybe I'm just searching the wrong things on google.
Thanks 🙂
Thanks 🙂
Alright... I'll have a look. I looked up weatherstripping on google translate and the word "tætningsliste" came out in danish. Looks like what I'm really looking for when I search google with this word. Thanks both of you 🙂
You can buy rubber gasket (selvklæbende gummilister) in 'Silvan' for something like 6-10dkr/m
So its very cheap 🙂
Yeah but they have to be like 10 mm in thickness or maybe more. It goes on the grill (which is glued on the speaker itself) so the speakers will fit with "the new design" (like darkwithin mentioned some pages back). I know what you're referring to, but that's normally like 3 mm thick or something. And when you put pressure on it, it shrinks 2/3 or something like that. I'll see what I can get in Silvan or my local hardware store (Østerbro Tømmerhandel - very local 😛)
We're talking about something else than you.. We're talking about a gasket round the LID of his boombox 🙂
Regarding your question..
Why go through all those troubles finding a gasket for the drivers? You could just change the measurements of the compartments to fit the right internal volume.
If your inner measures are e.g:
25x25x25 = 15,625 liters
Just make it a bit thinner and a tiny bit taller so you get maybe:
23x25x27,2 = 15,640 liters
That way you don't have to fit a homemade rubber gasket 🙂
I don't want to mess with Saturnus perfect construction. Plus I have already bought the wood pre-cut according to the google sketchup drawing. No turning back 🙂 Besides I want this to be as Saturnus intended it to be.
The most natural thing would be to make it longer though. However, it shouldn't be too hard to find a sealing band that compressed makes about 5mm. Just ask for it in the local hardware store. If it's a huge problem you could also get some masonite board and mount that on the inside, and cut away what you don't need. Masonite board is typically 3.5-4mm thick.
And there's also a neat side effect of the deeper placement of the driver in that if you mount the grills directly on the driver then with the deeper placement the tip of the grill doesn't protrude farther out than the front which in my opinion is more appealing aesthetically.
- Class D
- The Boominator - another stab at the ultimate party machine
