Im come back
I did the layout for low shunt Salas, just watch and comment me!
Thank you all!
Pm: on PCb have 5 shunt supply, you can separate them
2. x 1.5 to 5V
2 x 5 to 35V
1 x -5V to -35V
Thank you all!
2. x 1.5 to 5V
2 x 5 to 35V
1 x -5V to -35V
Are all suggestions for improvement inplemented in your current design ?
What will be the price for a 5PSU PCB including shipping?
Jan
Jan
HI Quanghao,
I did not receive the 3 sets of PCB that i ordered in the last group buy .
Is there any consideration for me to get some of these PCB in the future group buy ?
thanks
kp93300
thanks
kp93300
Hi! I was sent to you 7 PCB Salas low shunt 2 week ago!
When you get it, please tel me!
3 pcb i will sent you later, when i finis the new GR!
7 boards arrived today ! Thank you very much Quanghao, this was an unexpected treat.
I am happy to call us even, there is no need to send the remaining three boards. You can put that savings toward the cost of the registered shipping.
HI Quanghao,
thanks
kp93300
Me too, I did not receive my set of PCB 🙁
Yes, i see it!
The last GR , i will sent agin to you!
Hello Quanghao,
I too am waiting for three sets of boards from the first GB. I paid for 4 sets and only received one. This is just a reminder so that you do not forget these as well as the others.
Thanks,
Dave
fitzfish
Thanks,
Dave
fitzfish
I built a complete board and get max 4.3VDC out of the 1.5V-5V module. What would be involved in configuring it for 5VDC(or more)?
increase Vref.I built a complete board and get max 4.3VDC out of the 1.5V-5V module. What would be involved in configuring it for 5VDC(or more)?
guys can you help me a little?
i finished 3 boards and none of the works ok.
the led L4 doesn`t burn in all three of them and i can`t adjust output.
one of them outputs 10volt and the other 2 14.5volt.
i tested them with a 12vac trafo.
i changed the led at one of them but it`s not the problem.
propably i damaged some parts because soldering was hard.
this pcb needs high temp to solder.
can you point what to look first?
all boards are 5-35v positive.
thanks in advance.
thanks in advance.
any of these boards available?
please give me some times!
For 5Vout use 5-35V module.
thanks in advance.
What's your Vout target? could you post some pics?
- Group Buys
- Salas low shunt Group-design by Salas
