The version is displayed on the UI (WindowsApplication1.exe).
It should be 1.2
Please try the original link...
cheers
It should be 1.2
cheers
There is a basic user interface, try WindowsApplication1.exe 🙂
Version 1.2 is already up, sounding even better (in my opinion).
You can download it using the initial link (http://pure.truefreehost.com/pureplayer.zip)
Thanks...
It seems to sounds different to (sounds leaner and perceived to be cleaner) the previous version 1.1, I use it with Fidelizer version 1.1, this combo sounds quite good. I am listening right now.
I prefer v1.1 because v1.2 is too lean it seems to shift the Freq. resp upwards. V1.1 works well with Fidelizer 1.1.
Thanks for your feedback.
I listened carefully and it seems you are right.
New version 1.2 is available through the same link with the sound engine of 1.1
pureplayer v1.1 ---> MEGAUPLOAD - The leading online storage and file delivery service
pureplayer v1.2 ---> MEGAUPLOAD - The leading online storage and file delivery service
fidelizer...........---> http://www.windowsxlive.net/download/fidelizer.zip
Small guide how to use it:
1. Deactivate virtual memory (if possible >3GB ram)
2. Fidelizer ---> audiophile
3. pureplayer needs Netframework 4 ---> Download details: Microsoft .NET Framework 4 (Web Installer)
4. pureplayer (when dos window appears wait a few seconds to convert the audio file to wav=unknown file! (cd = rip))
enjoy
enjoy
In order to resolve the link problems the latest version (you will need only this) has been uploaded to http://www.purediy.gr/downloads/pureplayer.zip Just click it
You can download the latest version from now on using this link.
Thanks again,
Nikos
Thanks again,
Nikos
i have problem with NORTON2011
they keep on deleting the windowsapplication1.exe, consider as THREAT.
what would be the reason for this?
cheers
henry
cheers
henry
It a simple VB.NET application that executes cmd commands.
You are the first having problem with it.
You could possibly disable the Antivirus just for a test...
I'm listening through PurePlay right now and it really is better than foobar, at least to my ears...I got that urge to listen to all of my favorite tracks...
imediately...
Congratulations, great work!
imediately...
I'm by no means seasoned/trained listener, but I'd say PurePlay shows significantly more details and attack, deeper and a bit wider stage.
Tried flac, ape and mp3 with no problems except in one case when player refused to accept all mp3's from one album...when I drop (or try to open) file, nothing happens...I already thought I'll make a joke about PurePlay being really "purist" player because of refusing to play lossy files, but all other mp3's play just fine... 🙂
Next step: try PurePlay with Fidelizer...
One more time, congratulations, I'd be proud if I were you...
hey guys and gals,
I downloaded fidelizer and set to audiophile...how can I find it again? Does not show up in Programs...? Thanks.
The best sound I get so far includes the following:
1. Pure Player Version 1.1
2. Fidelizer Version 1.1
3. Set window 7 to no virtual memory, I use 2 core cpu running at 2.0Ghz
4. I have 2 G of memory no harm of having more memory.
5. Turn off Screen after 2-3 min helps.
6. I use a laptop, run on battery if necessary.
7. Remove all unnecessary background programs.
8. Disable all unnecessary ports e.g. Sound card(I am using ext. DAC), modem, etc
I get very low system latency, below 100ms most of the time averaging around 40-60ms, the cpu utilization is below 4% most of the time.
The sound is very clean and balance. Try it.
Well done Nikos,
It sounds really good - need to do some long term listening.
I'm using Win 7 SP1 & when I changed Foobar from KS output to Wasapi there was a distinct & large improvement in sound (Foobar under XP using KS output has exclusive control over the soundcard i.e no windows mixer, in Win 7 that's not the case)
Does Pure Player use Wasapi drivers? I see that the windows mixer is operational!
Also, are you converting 24bit to 16bit using SOX for playback?
Yes, well done. It certainly sounds very good - and with fidelizer, even better.
Would be nice to be able to play wma files - just because I have a load of them!! and pause & search would be good too. But not too worried about either of them really.
Interestingly, I had been using foobar for quite a while now and was fairly happy with it. I don't do as much headphone listening as I used to, but I always had a little odd noise in the background, which I always put down to dirty ground in the PC. Anyway, its gone tonight using pureplayer/fidelizer. Might just be chance, and would need to check on more occasions, but that would be quite the achievement if it was really gone!!
Fran
Fran
Fran
Fran
One thing that's also noticeable (with all the top quality players, I think) is the difference in sound between FLAC & WAV. Try it Fran & see if you agree. I use dbpoweramp to convert from FLAC to WAV - it seems to do a nice job.
In the short time I have used it, I haven't noticed any difference with Fidelizer. I use Win 7 SP1 (only on beta release) which is said to be th ebest sounding Win version so far - anybody else using this & tried Fidelizer?
see post 52, I prefer Fedelizer version 1.1 to version 1.4.
You mean Wav sounds better than Flac in most cases?
Got a link to 1.1?see post 52, I prefer Fedelizer version 1.1 to version 1.4.
Yep, in all cases so far!You mean Wav sounds better than Flac in most cases?
hi ttan98,
could u please give us the link to fidelizer 1.1? i think the current link only for 1.4.
thanks for the setup info.
cheers
henry
cheers
henry
hi ttan98,
cheers
henry
WindowsX has removed it, PM me I will email you a copy.
Nikos,
I like your Pure Player version 1.1 and even J. Keny praises it. I hope you don't mind if you can accept my constructive criticisms,
Pure Player as it is not really a Prototype but rather an Engineering Model. My suggestions are as follows will make it a Prototype:
1. Retain the sound engine as it is and improves on the USER Interface, with the following features:
a. No more DOS cmd display
b. Able to add tracks while player is playing
c. Play next track
d. Pause and Start
and many more, I am sure you can think of. A good starting point is from Foobar. Thanks for listening.
c. Play next track
d. Pause and Start
- PC Based
- Pure Player
