Digital RIAA can easily do .0001dB and .001 degree phase.
I'm not surprised. But my question to JC is what demonstrated criteria is the specification based on. An engineer defines requirements based on some functional need. He doesn't wet his finger and stick it in the air to see which way the wind is blowing that day. So what I'd like to know is how did JC arrive at his spec? If he were to tell me that a documented study shows that 95% of people can hear a difference of +/- 0.2 db at 20khz and he wanted a 100% safety margin then I could accept that. What I can't accept is that he tells me in one breath he's an engineer and in another that he selects a performance specification that his equipment must meet out of thin air because that's what he likes or because that's "his" experience. Engineers, that is real ones have a rational reason for what they do. If they don't, then it's not engineering. It may be advertising but it's not engineering.
I found this :
Audio, Meet Science | Stereophile.com
Maybe John is a "Real Life Engineer".
Specific tests may not be valid for a number of reasons. The science isn't sufficiently advanced to devise meaningful tests that examine salient variables. The tests fail to simulate real world conditions but are inherited from a more primitive time when they were once meaningful. There are more variables in the test procedure than it controls and one variable at a time is not being tested but multiple variables are at work simultaneously. There are others.
That tests are flawed does not negate the fact that they are the only reliable way to determine the limits of perception among those being tested. The claim of the so called subjectivists is that the process of testing itself is not valid. Nothing could be further from the truth. The problem for someone who genuinely believes he has made a discovery or devised something truly innovative is to devise a test which proves it. That is exactly the opposite of what audiophiles do. They only use tests and measurements to justify opinions when it is convenient to prove a point they arrived at irrationally and when the opposite is true, they reject the idea that tests prove anything. Now what about that blowtorch preamplifier?
Let's examine that statement.
Ultimately, the end goal is to sell product and make money.
That requires marketing and advertising.
And in this market, as with many others sadly, playing the numbers game is a highly effective marketing tool.
The numbers are achieved through engineering.
Therefore, does the engineer in this case not have a rational reason for what they do?
Surely you're not arguing that the desire to make money is irrational are you?
se
I hate to say it guys, but the reason I use .1dB is because I can, with 1% parts and a good engineering design that optimizes the tradeoffs. That is all there is to it. The very idea that Lipshitz might think that it is important, only contributes to my effort. After all, RIAA has been essentially defined by Lipshitz and Jung. That is what I use to map to.
Originally posted by jcx
curious minds do wonder why we're seeing seemingly randomly chosen, poorly contextualized objections rather than comments on measurements, datasheet numbers of existing MC xfmr for the bandwidth, flatness issues, or valid information from the cited sources translated to the conditions of the MC xfmr circuit model
http://www.jensen-transformers.com/an/Audio Transformers Chapter.pdf
George
Fortunately "P-type" tubes were not invented so we don't listen to horrible sounding symmetrical cathode followers. 😀
I am joking Bob, but very seriously.
FYI, masking effect means the closer harmonics are to fundamental frequency, the less they are audible. But I know the rumor exists that high level of low order harmonics make high order harmonics inaudible, but it is not true. All of them, from fundamental frequency and up, mask closest higher order harmonics. 2'nd order does not mask 7'th, 8'th, 9'th, etc... harmonics. It masks the 3'rd order one, but up to some relative level only, and the higher is the loudness of the entire sound, the better it masks.
Hi wavebourn,
True, but bear in mind that it is not just harmonics that must be considered; we don't just listen to sine waves, so IM products are important. Their specing can be entirely different from things they may mask. This is why it is wrong for people to suggest that 20 kHz THD doesn't matter even if they don't thing signals above 20 kHz are audible. Where you have 20 kHz THD, you will surely hear IM as well, which can easily fall in-band.
This is one reason I strongly prefer the 19+20kHz CCIF test with spectral analysis. This approach to evaluating amplifier distortion is even more important with the advent of class D amplifiers with output filters which may attenuate the THD harmonics.
Bob
Hi wavebourn,
Bob
19+20kHz CCIF test is better than only THD, but it's not enough, because of it ignores transients that are present in music signals.
And your explanation for this? (I have mine, which I think you can guess)
OK SY,
So you never did get back to me on if the wet playing induced noise in a record decreases from the start groove to the inner. Your theory that it is a property of velocity should have the noise decrease by more than 10 db. Should be obvious even with out test gear.
Now you doubt my completely scientific demonstration with every know and several previously unknown variables well controlled. Eh! Try it for yourself. I think you will quickly understand why it is not described as a sound but is noticed.
After that I'll mention how low frequencies can make folks queasy. Great for a Halloween haunted house.
ES
What's the easiest way for us to follow your advice John? Are those journals available online for example, and if so do we have to sign up to the AES to get them?
You'd have to go through all the issues, decide which articles you wanted, and then buy them at $20 a pop.
They do have an anthology on disk recording in two volumes for $74, but they're currently out of stock.
se
