Moderator
Joined 2004
Part 1 is here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=71189
Hi John,
I posted the following in a post I moved to the test equipment thread. It really belongs here, so I am going to quote it.
I don't know if you read that post, you didn't respond to it. So here goes ...
At this point, is there any reason to hide your actual schematics? It's an old design that depends on discontinued devices and careful hand construction. The PCB details are enough to stop a clone.
The reason I ask is that you could refer to specific design examples as you pointed out your design choices, or what you consider to be important concepts. It would be somewhat easier to keep things on track and clear to other people.
Considering the difficulties a normal person would have to begin production on anything, there really is not a lot to worry about there either. I do not want to make one of these, but learning from this would be very useful to many.
Just a thought John.
Let's focus on John's discrete design again. If we can reference to the actual design while we talk, it may help considerably.
-Chris
Edit: The original thread is here, a big thank you to stinius who reminded me that I forgot to link to the original thread.
Bob Cordell said:
I have never measured PIM in a tube amplifier, but it might be interesting to do. One might be able to make an argument that tube amplifiers may have significant PIM as a result of the quasi-saturation that high-amplitude low-frequency signals cause in the output transformer.
Fortunately "P-type" tubes were not invented so we don't listen to horrible sounding symmetrical cathode followers. 😀
I am joking Bob, but very seriously.
FYI, masking effect means the closer harmonics are to fundamental frequency, the less they are audible. But I know the rumor exists that high level of low order harmonics make high order harmonics inaudible, but it is not true. All of them, from fundamental frequency and up, mask closest higher order harmonics. 2'nd order does not mask 7'th, 8'th, 9'th, etc... harmonics. It masks the 3'rd order one, but up to some relative level only, and the higher is the loudness of the entire sound, the better it masks.
Okay. Leinonen, Otala, Curl.: A Method for Measuring Transient Intermodulation Distortion (TIM)*
3.18kHz square + 15kHz sine, test signal spectrum:
john curl said:
I hate to quibble, CV, but a 2-3dB difference between 15KHz and 15.7KHz with a 100K -3dB down point?
I assume he has generated the signal in digital domain, and used Lynx L22 DAC output.
Anyway, speaking about grass, I mean dynamic range of 140 - 160dB. I know it is inaudible at sine. But the high order grass is an indicator of certain type of sound. Multitone with to many tones confuses the issue, 19+20kHz is okay.
Everyone, and anyone who wants to know about the BLOWTORCH principles, limitations and costs, just look at the first 100 pages of the previous Blowtorch thread. Everything else, don't count on it, even though there are a few nuggets of wisdom, interspersed throughout.
