My listening room. Hornes with Fostex FE 206E
Fro left to right on the shelf:
SE 6Ф3П, SE 2A3 RCA, OTL 6AS7, EL11 Telefunken, PP 6П3С - variant Leibowitz.
On the floor: PP 6005 - variant Leibowitz, SE 300B JJ, SE 6С4С, SE EL11 Tungsram.
https://picasaweb.google.com/azazello52/Amplifiers#5582500460015416338
My 1st tube amp - still under construction but main electronic parts of the project already finished ~1month ago.
Already working:
1. amplifier (4x EL34, 2x ECC82, 2x 6N6P),fixed bias, voltage stabilisators for 285V, 420V, -60V and 6,3V (with slow voltage increase function). Delay for HV.
2. tone control +/- 6dB, 2 points with relay to switch off (goal for next winter to prepare tube preamplifier with tone cntrol and HI END DAC)
3. remote control for ALPS potentiometer and on/off for hole amp.
Under construction
1. VU meter based on 2xEM84 (PCBs already done)
2. chassis (AL + INOX + GLASS = modern look)
Sound? Incredible... It's pupming to Jamo S606 speakers to 25sqm room.
Already working:
Under construction
Any chance of the schematic linked to the Nixie tube 🙂
it needs about 150V on the anode, switch kathode to gnd with the selector switch. I used one to indicate the input selection
My Tubelab SE......
nice!!
no humm humm humm....
cool keeping the AC away from it all
are the tubes DC heated?
Yesterday I finished Red Light District amp based on Russian pentodes 6p14. Polish custom OPT by 4pietro. Chassis - recycled from 3Com ethernet hub - did not have to drill LED holes.
what do the LED's do?
apart from emitting red light?
GM100 Stereo
I thought of using an OFF led in my new project
A GM100 SE STEREO amp.
You can definitely see when it's on.
At 17V 20A
Will take some time, doing the scematics.
I'll go for 40W SE or so
The RS607 looks like a little baby...
At 17V 20A
Can have a glance on the schematic please (driver ECC82/6N6P especially)?
Bias for output pentodes' pairs. See Sy's webpage or his thread on diyaudio for schematics.Yesterday I finished Red Light District amp based on Russian pentodes 6p14. Polish custom OPT by 4pietro. Chassis - recycled from 3Com ethernet hub - did not have to drill LED holes.
My take on a scratch built Dynaco ST-70. The only original ST-70 parts are the output transformers. Hand made chassis that I had chrome plated.
nice!!
yes, the tubes are DC heated in the tubelab SE (with a 5A regulator)
Beautiful and original design, love the round shape
Beautiful and original design, love the round shape![]()
Thank you. I had built a battery powered tube pre with the same design and liked it so much, I built this.
Hello
Can someone help me with a good 6L6GC tube amp schematic, please.😉
Something not over complicated.
Probably not the best place to ask but when I see all those nice tube gears hard to resist not to ask. Also want to follow these post.
PP or SE , I'm interested on both, I will buy all the parts after I found a good schematic.
Specially if runs high voltage power supp.
Greetings gabor🙂
Greetings gabor🙂
Hello
Some options here, please.
Hello
Probably not the best place to ask ......
Gabor-
You'll get more responses if you start a new thread in this section of the forum.
This link should get you started..
Just use a title like: 'Looking for simple 6L6 amp schematic' or similar...
Sure - project described on this site: Gegentakt-Verstärker in AB-Betrieb für EL34 / 6L6GC
Orginal schematic
http://www.jogis-roehrenbude.de/Leserbriefe/Roessler-Amp/Schaltung-ES.gif
Canceled VB408, I did stabilisator by use IRFP820 and Zener diodes (similar like for the EL34 Anodes).
As I said - chassis during preparation (aluminium milling, anodicoxidation, then assy, and top preparation - inox laser cutting etc). Should be ready in 2 months.
- Tubes / Valves
- Photo Gallery
