Thanks again for your help Paul
I have a a lot of work to do here I think. I am looking at your OB/amp project thread and thinking along the lines of buying the Jensem 15" drivers and using a similar U baffle to yours.
Thanks for the offer of helping with the design but I think I`ll stick to tried and tested format.
How do the Purples sound in your U baffle?
Cheers
Alan
Cheers
Alan
recommend Loctite brand super glue. ]
most of the 500 series loctites come right off with a bit of acetone.
I need to try that. The whizzer is awfully close to where the cone meets the VC, so caution will be warranted!
For any fence sitters: I'm down to a handful of pairs! If you are thinking about grabbing one, do it ASAP!
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Paul
Hi Paul,
I've ordered 4 of your purple speakers, and have a few quick questions.
I assume a nominal impedance around 8 ohms? I might run two in parallel and my amp is rated down to 4 ohms.
I saw the whizzerless (is that a word?) graph in your post. Have you graphed the driver with whizzer? The reason I ask is I'm considering running a tweeter with a first order crossover, and am curious as to the frequency I might crossover. 8 khz, 10 khz, etc.?
They were priced at a point where I can play a little before I finalize plans...
Thanks!
John
Thanks!
John
John,
They are 8 ohm speakers. Comb filtering is the potential problem with running two per side (the phase difference between the two speakers resulting in deep and frequent nulls in the frequency response above a frequency determined by driver spacing). Some folks claim the problem isn't audible. I'd be curious to see someone play with it, as I frequently have folks interested in running two per side and I'd be happy to sell more speakers!
I can try and dig up a graph with whizzers. But if you are running a tweeter, I'd either cut them into dustcaps or use a phase plug (diy or Planet10). May as well give the tweeter something to do, and avoid the imperfections of the whizzer! The crossover will be application specific. For example, if you're running a really efficient tweeter and a single cap, you might choose a higher than technically perfect electrical crossover point in an effort to bring the actual in line with the Purple. But assuming equal efficiency, whizzerless, you're looking at 7-8khz. With a whizzer, I'd say 12-16khz, depending on which whizzer you choose.
Paul
Paul
Hi Paul, any of these purple speakers left?
At least one pair. Maybe a few more. I'll have to check the basement as we are getting close to the end!
Paul
I do, and I just replied to your PM. For those still contemplating, I've got a couple of pairs left. Several have expressed interest, but until they are paid for, they are still available to anyone. I'll certainly post here when I have run out, so until then, you can assume I've got at least a couple floating around.
Paul
Paul
Another order. I'm down to one pair of regular stock Purples! I also have one with a lightly dinged basket, one with a big whizzer installed, and one with a dustcap. I'll take $10 for each of those three. It bears repeating: these are the last I'll ever have available!
Paul
Paul
The big whizzer and dustcap units are gone. I've had folks express interest in the last pair, but no paypal yet! So I still have three for sale.
Paul
Paul
I believe all I have left is the single with the dinged frame! I'll let you know if I miscounted.
Paul
Paul
Like I said above, all I have left is the single, no pairs! For those who are looking for speakers, the Betsy and BetsyK really are better in every way, and they aren't to expensive at $50 and $55 each, respectively!
Paul
Paul
Received mine today! cant wait to test these out! Paul, is your recommended break-in procedure written down somewhere?
I keep forgetting to post it, but the single is gone. That means there is no safety net, should you get glue in the gap. I have no replacements, so be careful! (Only one person has had a problem, the single is now in their hands). I like the "gel" loctite because it doesn't run.
Paul
Paul
Just wanted to say at after a few months with these speakers, listening every day, I am still in awe. My room is on the small side, but after a long break in they are really perfect to my ears (and most everyone that comes over)
So, whens the next "experimental" speaker coming out from Wild Burro Audio?
Which whizzer did you use? Still can't figure out which to use on mine. 😛
The directionality of the BetsyKs is inconvenient to me, in my small, heavily obstructed room. By no fault of their design of course. Is it possible that using a smaller whizzer will decrease directionality, and improve HF behavior? And allow me to equalize out HF rolloff?
- keantoken
- keantoken
there was a 3 page thread started in march on what a whizzer does, very informative with graphs before and after whizzer removal. Yet other threads people like large or small whizzers, but not 8" whizzers for some reason. My an10 has a tiny whizzer, but I've never hooked it up. People seem to like the huge whizzer on the 12lta also, and people seem to like the whizzer on the fe166e and fe167e, and some like whizzers on even smaller drivers.
Here's the link.....
http://www.diyaudio.com/forums/full-range/185012-whizzer-intelligibility.html
The whizzer on an 8" helps dispersion from 2khz-4khz. If you cut off the whizzer (on a flat coral 8a anyway), the drivers response climbed from 1.5khz around 6khz, then fell off above that.
Otherwise the phase is wonky, especially where the whizzer and cone are both operating.
And yea, to me an 8" full ranger (even with a whizzer) is maybe 2 people wide dispersion up to past 5khz at 12' (using 8" whizzer no phase plug and a different 8" with phase plug).
p.s. those purples seem to have had an excellent freq response.
Norman
Norman
Im using the medium whizzers. I dont have a problem with the dispersion, but it is noticeable if you sit in weird places. But generally its good.
- More Vendors...
- Wild Burro Audio
- The Purple speaker: an $18, 8" fullrange!
