Preamp with buffer design
Ok, after a week of searching and reading, following the suggestions made by forum members on various posts, I decided to make a passive preamp for my quad 405 (linestage only). Having said that, since I will build a tube preamp for my phono stage in any case, I'm thinking, let's add the possibility to switch from passive to tube buffer in the preamp for the linestage.
I have found a few possibly suitable tubes in my stuff (salvaged mostly): 2 x 6922(unused!), 2 x 6cg7 and 2 x 12ax7. I also have old preamp boards, unpopulated, that I would like to use, even if I leave a few areas unpopulated on them. The schematic is as follows, and I was thinking of having the first stage with V1 left blank and using only the second stage (cathode follower) for buffer purposes. Since both channels are using the same tube, where do I connect the B+ on that schematic? Also, what do I do with r6 r16 r18 (what is their use)?
I am tube newb, so a few things are still unclear to me... please assume I am 5 years old when you explain something to me 😉 (I'm afraid I'm good with numbers, but not all the technical terms as of yet...)
It is a preamp board I had in my random stuff pile, it looks like the picture attached. Sorry for the crappy quality, I was in a hurry, I'll take a better one if needed. I have two btw, so I can experiment on one. The circuit is quite visible, I'd like to remove the part under the toroid hole, cause I have two transfos, one for hv, one for lv.
Splitting r16 is feasible, what about c6 and r4?
Thanks.
You, sir, are making a lot of sense... the schematic looks way nicer that way. I thought I was missing something, and there it is, it's single sided!
Is the idea of bypassing the gain stage a good one? or is there another way of achieving unity gain apart from using only the cathode follower?
What are c6 and r4? Is there a name for such an arrangement?
John
C6 is a decoupler. It reduces noise and hum on the HT (B+) supply, and also reduces unwanted coupling between different stages.
R4 will simply use up current. It may be that it was originally part of an HT dropper arrangement.
The only other way to get unity gain is to use an anode/plate follower. This will have a lower input impedance than a cathode follower, and possibly more noise. It wil invert the signal.
Alright then, since I'm aiming the 200v range B+, perhaps 3x51v zener and a diode would do the trick there. Is there a power transistor that is usually used in this type of circuit, or does any general use transistor work as well? Once the psu gets figured out, having solved the mystery or the weird resistors, I'll be able to start building this! yay
I'll bypass the gain stage as I originally thought, seems to make more sense.
Thanks, I know i'll have more questions though.
How does this look?
Ok, finally finished rethinking the whole thing, it looks like this. Part values ans selection was done with quick calculations and trying to match parts I already have on hand... Still, I can change them if I'm way off.
So, anything wrong with this? Should I consider something else?
thanks
