HiFi Tube amp project
Hello!
I have from now until mid-may to design, test, refine and complete a 10-15W hifi stereo tube amp, and was hoping to get help, suggestions, and comments for this project.
Me and a friend built a pair of bass-reflex enclosures with Pioneers B20FU20's in them last semester - I'd be designing that amp for specifically for those. He's building me a guitar in exchange.
Requirements are pretty basic:
-10-15W/channel
-cost kept in the 400$ range
-be able to work with a variety of sources (from record player to ipod) and have multiple ins
-basic tone control, with maybe a bass & treble boost pots, but nothing complicated
-be very sturdy (foolproof). We all make mistakes (forget to plug in the speakers - I'd like to know how to make an amp that can survive anything).
I've been doing research in more "unusual" tube cicuits, which led me to be considering some combination of the following options:
-ultralinear output stage
-parallel triodes for the preamp
-gated beam discriminators (à la Pete Millett's Magicbox, very uncertain - would it actually be useful at all?)
-solid state power supply
-compactrons:
*triple triodes for the preamp (6AC10; 6AK10,6MJ8...)
*double pentodes for a self contained push-pull output stage (6BN11, 6BV11)
*Or double triodes + pentode, such as the 6AS11, to contain one whole channel in one or two tubes, although apparently the interactions within the tube make this unrealistic (AX84.com - The Cooperative Tube Guitar Amp Project)
*maybe a 6Z10 if I actually end up wanting a 6BN6
Experimentation will be a big part of this project, but I'm going to be making refining schematics of different versions in order to get parts and start testing around 3 weeks from now.
I'll add many many details as this project kicks in. Comments, suggestions, questions are very appreciated! This project is supposed to be an opportunity to understand how to design a product from start to finish - I'm learning here, all help is appreciated!
Thanks,
Ezra
An "El Cheapo" using UL mode "finals" will yield an honest 12 WPC. You should have little trouble in meeting the $400 budget limit, if you build with Edcor O/P trafos.
Tone controls can easily be "a can of worms". A truly decent tone control setup is fairly complex and implies some expense.
The 'AQ5 shown in the schematic is, for all intents and purposes, a 6V6 in a 7 pin mini package. Any member of the 6V6 "clan", including the 7C5 and 12AB5, can be used.
Read the LENGTHY saga of "El Cheapo" here. It's a lot to wade through, but you'll get some ideas about circuit design, necessary compromises, and parts selection.
Hello!
Doesn't the assignment disqualify you from just copying an existing design?
My suggestion would be to 'hit the books' - Morgan Jones would be one place to start - and get working on your design, 'from the ground up'.
Keep us posted with your progress. It should be an interesting project.
John
The assignment is as hard as I make it for myself. Of course, chances are each stage is going to resemble something that's been made before, but I'd like the overall schematic to be mostly my own...
I'll be taking a look at the Jones book very soon. I'm trying to avoid the "cookbook" approach though - my goal is not only to design something functional, but also to understand exactly what every component does and why it's a certain value.
The El Cheapo Power Stage is somewhat in the range of what I'd need, and I was actually looking at using 6AQ5As. Thanks for suggesting that.
I was looking at the Engineer's amp, mostly because it advertised itself as fairly accessible and *built with a big red PCB*. However it's way more powerful than I need the amp to be. I guess I could spend this whole semester designing a preamp for it, but that would make me go over my preferred investments and end up with something probably to beasty.
I'll be uploading schematics for different stages as I work with my instructor on those and figure out how to use eagle (or get annoyed at computers and draw everything by hand then scan) - thanks already for the interest and replies!
Ezra
That's exactly where Morgan's book excels. The Bevois Valley is a nice design exercise and could be a model for your eventual design path.
Four months is not a long time to learn about valve amps, even if you are already an expert on sand circuits. I assume you need time to eat, sleep, watch TV etc. too? I think you need to decide now whether you would prefer to complete a glorious failure with lots of badly working bells and whistles, or achieve a more modest success and then try something more challenging next time. I realise this will make me sound like a boring old f**t!
Sounds like a fun project.
I completely agree with DF96. Your time is short! Make it count.
My suggestion would be to take a basic, yet known good, amplifier circuit (such as a Mullard 5-20 as one example), and use different tubes. This forces you through the design/calculation process and should get you a good working "product" in the end, without all the time spent deciding between all available topology options at each turn.
Solid state power rectification is a good detour. Take that fork in the road.
There are lots of options you can add later if time permits, to tweak things. (CCS, tone controls, etc.)
Start at the end; pick the output tubes, and work backwards to determine what everything else needs to be. If you're going push-pull/Ultralinear it will be really easy to exceed the design goal of 10-15 watts, so think small. Using push-pull Triode mode will keep that goal within easy range.
Ask for direction, not answers, or you won't learn much.
Good luck,
..Todd
Thanks already for all the advice, everyone!
here's what I'm thinking so far: SE output section, with an EL34 (or any other similar power tube), into an UL transformer such as:
EDCOR Electronics Corporation. XSE25-4-7.6K
And a simple preamp stage with a pair or trio of parallel triodes. Why parallel triodes? I'm not sure. I think the idea is pretty interesting, it seems to have convenient advantages for hifi, and I really want to use triple triode compactrons, all paralleled, as a line stage, out of curiosity. comments concerning my lack of logic concerning this are more then welcome.
More than the UL operation, I'd really like to make this design my own by cleverly using compactrons. At this point, seems like I'll be using triple triodes with an EL34 power stage, unless I finally find a double triode+pentode that could work in UL and preferably provide enough power without P-P. Horizontal Sweep tubes were recommended but I'm incapable of finding one appropriate for UL operation because of their g2 max voltage ratings.
opinions? chances are, I'm going to give a shot at a few of those ideas and realize that there's no way I'll have time to make that work and resort to more classic options. I'll give it my best try though.
I've been using this website Compactron Tubes: A Junkbox Guide to browse compactrons. Anything better I should know about?
If a distortion analyzer is basically an FFT tool, then I can have access to one, it might simply not be sturdy enough (not sure it can take the voltage swing, although to be honest I might be worrying for nothing). I'm not sure I'll have the time to trace plate curves for this project, even if it's something I'd like to learn how to do soon.
Definitely planning on solid state rectification. Will have to get to that soon.
I'm going to have to make some quick decisions, as the deadline for funding requests is in 2 weeks and requires a fairly detailed list of parts.
just remembered I also liked beam tetrodes, but I'll keep decision-making for the snowy tomorrow.
Ezra
I would highly recommend the CXSE if budget allows...believe me...if not DEFINITELY go with the GXSE's. XSE's are good but the CXSE's will blow you away. I evolved my SimpleSE amp from using EL34's and the XSE's which was an OK combo to using KT88's and CXSE's. This little amp ROCKS now - from "meh" to "WOW" indeed.
From what I have gathered on the edcor OPT's:
up to 50mA - XSE
50-70mA - GXSE
>70 - CXSE
Again...RULES of Thumb...
Check out Tom McNally's Amps for some build inspiration...a few schematics there too...as well as some spud amps...
I was looking at that page...
Kind of unfair how well assembled and plentiful his amps are. If there was a model of internal arrangement I'd try to follow it'd probably be something Mr. McNally made...
will remember your CXSE advice. I don't need the power of a KT88, but I'll do my best to keep the budget for a good OT. I do need two of those though, and that's already a big chunk of budget, especially considering I still need to choose a PT... we'll see. Maybe I can scavenge parts somewhere?
The SimpleSE I have has the XPWR033 for PT and 2X CXSE's which totals about $250 or so...Figure another 100-150 for tubes - unless you shop ebay for bargains...
caps, resistors, sockets, misc hardware will run you another $75 or so.
You can get away cheaply with a chassis with a homemade wood frame and a Hammond top plate 10X12 or 10X17 or the like...probably about $30...
So you can get in for around $400-$500 - the tubes will be the key...If you go SS rectification then you only need driver and power tubes...
I have heard and seen this over and over again...Don's scrimp on your OPT's... and make sure your PT has enough headroom. You can easily figure a pre section running 10-20mA total plus a power section at anywhere from 80-200mA total depending on tube selection. Get at least a 200mA PT...Edcor has many...
Be aware though...Edcor has a long leadtime...figure at least 4-6 weeks.
Compactrons are usually quite cheap, which is one of the reasons I've been meaning to use them (that and the challenge to find a good one/design a circuit with it). They usually go at between 1 and 7$ a piece, which even if I get 2 el34 for a SE power section, means I should be getting away with around 50$ in tubes.
I had fun bending a sheet metal box for a project last semester so I'll probably just do a bigger one of those for this project. Maybe use leftover wood for good looking sides, Moog-style?
Thanks for the warning concerning Edcor's leadtime, I wasn't aware of that. I'll make sure to order transformers as soon as possible, as I probably won't be able to do any testing before that. That might be a good time to make said enclosure and figure out a couple details, maybe an alternate, simpler design if what I have in mind doesn't work?
Right now, considering the price of Edcor PP OTPs, I'm trying to pick a triode-pentode compactron that I can run in UL push pull. I'm looking to see if I could use the two triodes as phase inverter, and then have a triple parallel diode stage as the preamp.
Does that seem reasonable to the folks here? suggestions, maybe?
Ezra
Ezra,
You are suffering from compactron on the brain. 😉 An inexpensive 12AV7 CCS loaded by 10M45S ICs will yield ALL the gain both SE EL34/6CA7 "finals" require for proper drive. The high gm and low RP the 'V7 exhibits makes for excellent performance in the driver role.
1) NB: I meant triple parallel triodes. it doesn't make sense otherwise, but that was indeed a mistake - apologies.
I was looking at a schematic for switchable parallel/series double triode gain stage that looked pretty cool. Would probably try to implement that to some extent.
2) Compactrons got me pretty motivated. I guess I enjoy their cheapness and find it sad that they're so underutilized. I'll definitely be heading towards that "12AV7+10M455+ SE EL34" scheme in case of theoretical or practical failures.
3) I was hoping for some enlightenment input-wise: audio sources will include turntable, CD player, computer and mp3 player (people are versatile these days I guess). Guidance concerning the input impedance of this amp would be very appreciated!
Thanks,
Ezra
How about 20 watts /channel and simple to build, fantastic clarity and sound stage.... inexpensive output transformers about $45 for the set, tubes are about $4 each, power transformer was about $30 delivered, Sockets were $2.50 each, 400volt and 200volt caps in the power supply. Home brewed PCB with feed through eyelets for mounting the caps on the back side, on board power supply for B+ and adjustable fixed bias to allow for using mismatched tubes if you want. Inexpensive oak frame with a .080" 12"x12" alum top plate. Most online shops have 12"x12" standard size sheets.
Turned out to be a stocking stuffer at Christmas, the elves were very sad to see it go, had to build one for the workshop.....
Can be upgraded to 60watts/channel by larger output transformers and a new set of output tubes.
Working on the second one for 40/channel by upgrading the output iron, the third design will be 60 watts/channel with the larger output tubes and a bump in output iron.
Roline,
as much as I'd love to build and hear that amp, I'm looking to learn how to design amps - a kit/pre-designed circuit would defeat the purpose of this project.
It would definitely make me avoid all the mistakes I'm certain to make, but I'd rather go through those now than later.
Todd: thanks for keeping me serious. I need it. And "yanking your power cord"? I see what you did there - nice.
