100W Ultimate Fidelity Amplifier
apex,
where are you sir?
please post triac protection pcb,
i saw it in another thread before,
i cant find it now,
transistor replacement
Hi apex,
Looking forward to build ax14,I want to build a stereo set.
I am having a pair of 2ski530-2sj201,2 pairs
2sc2922-2sa1216-2 pairs
mjl21193-21194-5 pairs
can you suggest if i can use these for ax14, And what would be the optimum voltage to be used.
Also if i use higher voltages than recommended what precautions should i take-will bigger heat sink be a good option
what would this amp be class -A or Class-B
Also i want suggestions as how to get 300 watts rms with this amp.
I need to for tower speaker which have 2, 8inchers in 1 tower and rated at 200 watts rms at 8 ohms per woofer, so 2 woofers mean 400 watss rms
i used to diy a long back, its been several years, so i would need your guidance.
First post - Thanks to everybody - great thread!
AX14 pcb size: 60x82,5mm
For protect go to thread http://www.diyaudio.com/forums/solid-state/162081-dc-servo-mosfet-amplifier-3.html post #23.
Hi APEX, i like you schematics. Thank you fr sharing!
It looks to me nice and simple enough to try a a DIY ! I was reading all the thread 😛, and I found it very interesting. Since I tried to understand it all, Can you explain me why you have C3-R5 (Wahab at beginning had some words) and why D1? Are they necessary ?
And then that R3, won´t be better to split it in two emitter resistors for the LTP? Look, I am sure 100% you design is OK, I am only trying to understand a little bit how it works.
Thanks- ATX
